RGB to HSV conversion on FPGA
I had to know if there is any inbuilt function to convert RGB to HSV as cvtcolor could not be used to run on the FPGA. I want to run the function on ZCU104 through SDSoC. Can you please let me know if there is any other way to convert the RGBA image to HSV?
Thanks!
Thank you so much!
