Sdaccel hw integration error with rtl kernel
I am running a project with RTL kernel in SDAccel 2018.2 on VCU1525 platform.
I encounter an ERROR when I am doing hw emulation with the following messages:
ERROR: [VPL 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
ERROR: [VPL 60-399] vivado failed, please see log file for detail: '/home/jmu/bank/sdx_rtl/Emulation-HW/binary_container_1/link/vivado/vivado.log'
ERROR: [VPL 60-806] Failed to finish platform linker
ERROR: [XOCC 60-398] vpl failed
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
make: *** [binary_container_1.xclbin] Error 1
 I look into the vivado.log but there is no explicit reason for the failure. The log files are attached as below.
By the way, I use the auto-generated rtl template as the top wrapper but replace the kernel function with my design. I can successfully pass the simulation in Vivado xsim. Can anybody help with this problem?
Many thanks.
Hi, @gkillua36 ,
Please try to check the compile.log or elaborate.log in the below dir to see if there is other helpful info:
XX/Emulation-HW/krnl_XX/link/vivado/prj/prj.sim/sim_1/behav_gdb/xsim
