Share global memory between C/C++ kernels
Can data be shared between (C/C++) kernels in the same binary container xclbin? Does something exist which is similar to concept of global memory ("global int g_var0[4096];") in ocl for C/C++.
Thanks in advance
Hi, @snorwin ,
As I know, you cannot share between kernels currently.
Thanks, but is it possible to create a channel to exchange data between two kernels using a stream or some special ports?
Hi, @snorwin ,
Data written to global memory by a kernel can be directly read by another kernel, but it has to be controlled by host. You can search PLRAM in UG1023(V2018.3).
Hi @hongh,
Thank you for pointing that out. What is the difference between PLRAM and DDR?
PLRAM is the on-chip Memory.
DDR is intended to access off-chip memory.
Hi @snorwin,
For reference you can check the below example from public github regarding PLRAM usecase.
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/kernel_to_gmem/plram_access_c
