romanteau
Warning Message
After installing an alveo U200 board and SDAccel software. My card is well detected by the system and seen by the software. Nevertheless a Wraning message appears during the build :
WARNING: [XOCC 74-49] Failed to read in file /data/elec_soft/Xilinx_Software/Soft_2018.3/SDx/2018.3/platforms/achromatic during platform validation.
In fact this is caused by the installation of the runtime in the /opt directory under CentOS, while the SDAccel software is installed elsewhere than in /opt, which is normally possible. If /opt is too small to install the entire SDAccel, can you force the installation of the runtime into the same directory as the SDAccel software, that is not in /opt?
hongh
Hi, @romanteau ,
SDx doesn't need to be installed into /opt.
Is there enough space for you to install U200 Development Shell rpm into /opt dir?
romanteau
No, there is not enough free space in / opt to install all SDx, Vivado, etc.
The problem seems to be that we do not have the option of implementing a .rpm file. Its location is in the file itself.
hongh
In SDx 2018.3, the Xilinx Runtime/ Deployment Shell/Development Shell and SDx sofware are seperated.
The space in /opt dir cannot contain Xilinx Runtime/ Deployment Shell/Development Shell?
