What the *_offset mean in the hardward emulation?
After run the hardaware emulation, I can see the Function I/Os belonging to the port of a function in the sdaccel_timeline_trace.wdb file.
Also I noticed there is a *_offset I/O after each port of the Function.
What the *_offset indicate?
Thanks in advance.
Re: What the *_offset mean in the hardward emulation?
Hi, @mathmaxsean ,
The signals are generated in HLS called by SDAccel, you can try to ask for help in HLS board.
THanks.
