yanhan
assign SLRs of kcu1500 board on SDAccel 2018.3
Hi, all
I want to build my design for kcu1500 on SDx2018.3. But I cannot assign slr for kernels.
I have tried '--slr '  and  “ --xp param:compiler.userPostSysLinkTcl=/home/...../assign_slr.tcl”  link option, but both of them didn't work.
Does anyone know how to solve this?
heeran
Hi @yanhan,
Please check if valid SLR is mentioned in your platform file. For example below:
<SDxInstallationPath>/bin/platforminfo xilinx_vcu1525_dynamic_6_0/xilinx_vcu1525_dynamic_6_0.xpfm  | grep -i slr
Valid SLRs:
SLR0, SLR1, SLR2
If it is there, you should be able to specify SLR assignment. Following example can be referred for SLR Assignement:
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/kernel_to_gmem/slr_assign
-Heera
yanhan
Hi, @heeran
My platform is KCU1500, not VCU1525 or ALVEO......
And  there is no valid SLR is mentioned in the platform file.
In SDX2018.2 , I use extra tcl file to assign SLR like ug 1023 says.
SDX2018.3 has remove the part and use ' --slr ' link option instead. But this option is not supported by KCU1500.
graces
From UG1023,
Available device SLR resources which can be used for custom logic can be found in SDAccel Environments Release Notes, Installation, and Licensing Guide (UG1238) or can be displayed
using the platforminfo utility described in Platforminfo Utility.
The supported platforms in 2018.3 as documented in UG1238 are:
U200
U250
VCU1525
