ddr burst read doesn't work, stall happens.
Here is the code for read data from ddr.
Each data point contain 60 D_point_512 structure, i.e. 60x16 ap_fixed<32,8>  data.
After read 60  D_point_512 type of data from the port, I will put all 60x16 data to a structure "feature_or_buffer0" with 960 elements.
typedef struct point_512 //for floating/fixfloating point read ,the  data on port
    ap_fixed<32,8> x[16];
} D_point_512;
typedef struct point_or //for originla feature vector
Dtype_s x[960];
} D_point_or;
void read_feature_or(const D_point_512 *feature_or, Dtype_uint data_size, hls::stream<D_point_or> &feature_or_buffer0 ){ #pragma HLS INLINE off D_point_512 feature_or_temp[60]; #pragma HLS ARRAY_PARTITION variable=feature_or_temp->x complete dim=0 D_point_or feature_or_buffer_temp; #pragma HLS ARRAY_PARTITION variable=feature_or_buffer_temp.x complete dim=0 Dtype_uint loop_num = 60;// each 512 bit including 16 float data read_feature_pca0: for(Dtype_uint i=0; i < data_size; i++){ #pragma HLS LOOP_TRIPCOUNT min=10 max=10 #pragma HLS PIPELINE read_feature_or1: for(Dtype_uint j=0; j<60; j++){ #pragma HLS pipeline II= 1 feature_or_temp[j] = feature_or[i*60+ j]; } read_feature_or2: for(Dtype_uint j=0; j<60; j++){ #pragma HLS pipeline II= 1 //Dtype_uint inter = j*16; Dtype_uint inter = j<<4; read_feature_or3: for(Dtype_uint k=0; k<16; k++){ #pragma HLS unroll feature_or_buffer_temp.x[inter+k] = feature_or_temp[j].x[k]; } } feature_or_buffer0 << feature_or_buffer_temp; } }
From the wave-form after the hardware emulation I can see the 60 read from the DDR is not burst and stall happens.
The interval between the two yellow line is a 60 times read.
How to get rid of the stall and burst read the data?
An message was generated during the compilation( not sure whether this related to this issue).
INFO: [XFORM 203-811] Inferring multiple bus burst read of a total cumulative length 60 on port 'query_or.x' ( src/pcaf_fpga.cpp:107:2). These data requests might be further partitioned to multiple requests during RTL generation, based on max_read_burst_length or max_write_burst_length settings.
Re: ddr burst read doesn't work, stall happens.
From the ug902 I noticed that
When using a for loop to implement burst reads or writes, follow these requirements:
• Pipeline the loop
• Access addresses in increasing order
• Do not place accesses inside a conditional statement
• For nested loops, do not flatten loops, because this inhibits the burst operation
For my case the "read_fearture_0r1" loop  is nested in the "read_feature_pca0" loop.
If I pipeline the parent loop, i.e."read_feature_pca0", then the "read_fearture_0r1" loop will be unrolled automatically.
How shoud I resolve this conflict and enable the burst read?
Have you tried with DATA_PACK pragma? If it is still not working, can you share a simplified test case?
@yunl
Hi Yunl,
Thank you very much for you reply.
Yes I am using the data_pack pragma on the structure.
Each read from the feature_or port is a 512bit width.
The issue is the readings from this port is not that continuous and there is stall between two reads.
How Can I use burst read?
Hi @mathmaxsean,
It would help if you can send me a test case so that I can check it my end. If you are not willing to upload the case here, I can send your personal email an ezmove(secured ftp) link and you may upload the files there.
