Visitor loldaa
vcu1525 multi-bank error bug
Hi, everyone
I'm using the following environment
OS: centos 7.3
SDx:2017.4
board:vcu1525
dsa:xilinx_vcu1525_dynamic_5_0
The problem is  when I try to use the multi DDR banks,I cannot read (enqueueMigrateMemObjects) the correct data from other banks except bank0.
I already checked the software and hardware simulation results, they are totally OK.
However, in the real system run, it just can not return the correct value from devices to host memory.
And I can get the correct results from my other board KCU1500.
After some debug time I found a little strange thing here
I'm using DDR bank 3(it is clear since I using gmem3  also --sp map it to bank3 and all the related work), but the system report say It's DDR bank 2.
Then I think may be some problem with bank 3 so I change all interfaces bind to bank 2 but it showsp2.jpg
And, I must say again, in both cases I can get the correct date from soft and hardware simulation, but in system run the data from other banks (except bank 0)can not go back to host vector.
Through a lot of efforts  , I found something may be useful by using xbsak command
In the mem topology part, the mem sequence is not very reasonable.
By the way I can show the similar mem topology which KCU1500 used
I don't know this is the reason or not, does someone have the same problems?
Re: vcu1525 multi-bank error bug
Have you check the vivado log of system build? Are there any error or critical warning, especially timing violations?
Sean
