Visitor barry91
[BD 41-237] Bus Interface property ID_WIDTH does not match between /master_bridge_0/s_axi(1) and /m_axi_interconnect_M00_AXI/s00_couplers/auto_cc/M_AXI(8)
I am trying to follow the RTL Flow described in SDAccel UG to import a simple Verilog Kernel. I followed the step in the user guide, however, when I try to compile the .xo file to generate the .xclbin, the compiler returns:
I opened the Vivado Project, and I noticed that the error refers to two modules that have not been instantiated by me. Attached, you can see a picture of the design and the RTL kernel.
Am I doing something wrong?
Here, the code for the Verilog Kernel (it has been auto-generated using Chisel HDL)
module AdderAxi(
  input          ap_clk,
  input          ap_rst_n,
  input          m_axi_gmem_AWREADY,
  output         m_axi_gmem_AWVALID,
  output [63:0]  m_axi_gmem_AWADDR,
  output [2:0]   m_axi_gmem_AWSIZE,
  output [7:0]   m_axi_gmem_AWLEN,
  output [1:0]   m_axi_gmem_AWBURST,
  output [7:0]   m_axi_gmem_AWID,
  output         m_axi_gmem_AWLOCK,
  output [3:0]   m_axi_gmem_AWCACHE,
  output [2:0]   m_axi_gmem_AWPROT,
  output [3:0]   m_axi_gmem_AWQOS,
  input          m_axi_gmem_WREADY,
  output         m_axi_gmem_WVALID,
  output [511:0] m_axi_gmem_WDATA,
  output [63:0]  m_axi_gmem_WSTRB,
  output         m_axi_gmem_WLAST,
  output         m_axi_gmem_BREADY,
  input          m_axi_gmem_BVALID,
  input  [7:0]   m_axi_gmem_BID,
  input  [1:0]   m_axi_gmem_BRESP,
  input          m_axi_gmem_ARREADY,
  output         m_axi_gmem_ARVALID,
  output [63:0]  m_axi_gmem_ARADDR,
  output [2:0]   m_axi_gmem_ARSIZE,
  output [7:0]   m_axi_gmem_ARLEN,
  output [1:0]   m_axi_gmem_ARBURST,
  output [7:0]   m_axi_gmem_ARID,
  output         m_axi_gmem_ARLOCK,
  output [3:0]   m_axi_gmem_ARCACHE,
  output [2:0]   m_axi_gmem_ARPROT,
  output [3:0]   m_axi_gmem_ARQOS,
  output         m_axi_gmem_RREADY,
  input          m_axi_gmem_RVALID,
  input  [511:0] m_axi_gmem_RDATA,
  input  [7:0]   m_axi_gmem_RID,
  input          m_axi_gmem_RLAST,
  input  [1:0]   m_axi_gmem_RRESP,
  output         s_axi_control_AWREADY,
  input          s_axi_control_AWVALID,
  input  [63:0]  s_axi_control_AWADDR,
  input  [2:0]   s_axi_control_AWPROT,
  output         s_axi_control_WREADY,
  input          s_axi_control_WVALID,
  input  [31:0]  s_axi_control_WDATA,
  input  [3:0]   s_axi_control_WSTRB,
  input          s_axi_control_BREADY,
  output         s_axi_control_BVALID,
  output [1:0]   s_axi_control_BRESP,
  output         s_axi_control_ARREADY,
  input          s_axi_control_ARVALID,
  input  [63:0]  s_axi_control_ARADDR,
  input  [2:0]   s_axi_control_ARPROT,
  input          s_axi_control_RREADY,
  output         s_axi_control_RVALID,
  output [31:0]  s_axi_control_RDATA,
  output [1:0]   s_axi_control_RRESP
  reg  regStart;
  reg [31:0] _RAND_0;
  reg  regDone;
  reg [31:0] _RAND_1;
  reg [511:0] regDataReceived;
  reg [511:0] _RAND_2;
  reg [2:0] stateSlaveWrite;
  reg [31:0] _RAND_3;
  wire  _T_102;
  wire [2:0] _GEN_1;
  wire [2:0] _GEN_3;
  wire  _T_103;
  wire  _T_105;
  wire  _T_106;
  wire [511:0] _GEN_4;
  wire  _GEN_5;
  wire [2:0] _GEN_6;
  wire [511:0] _GEN_8;
  wire  _GEN_9;
  wire [2:0] _GEN_10;
  wire  _T_109;
  wire  _T_113;
  wire  _T_114;
  wire  _T_115;
  wire [2:0] _GEN_11;
  wire [2:0] _GEN_15;
  wire  _T_163;
  wire  _T_170;
  wire  _T_171;
  wire  _T_172;
  wire  _GEN_16;
  wire [2:0] _GEN_18;
  wire  _T_175;
  reg [2:0] stateSlaveRead;
  reg [31:0] _RAND_4;
  wire  _T_183;
  wire [2:0] _GEN_21;
  wire [2:0] _GEN_23;
  wire  _T_184;
  wire  _T_186;
  wire  _T_187;
  wire [1:0] _GEN_55;
  wire [1:0] _T_189;
  wire [2:0] _GEN_24;
  wire [2:0] _GEN_27;
  wire  _T_191;
  wire  _T_195;
  wire  _T_196;
  wire  _T_197;
  wire  _GEN_28;
  wire [2:0] _GEN_29;
  reg [4:0] value;
  reg [31:0] _RAND_5;
  reg  regFlagStart;
  reg [31:0] _RAND_6;
  reg  regStartWriting;
  reg [31:0] _RAND_7;
  wire  _T_208;
  wire  _T_209;
  wire  _T_211;
  wire [5:0] _T_213;
  wire [4:0] _T_214;
  wire [4:0] _GEN_30;
  wire [4:0] _GEN_31;
  wire  _GEN_32;
  wire  _T_218;
  wire  _T_220;
  wire  _T_221;
  wire [4:0] _GEN_34;
  wire  _T_229;
  wire  _T_231;
  wire  _T_232;
  wire  _GEN_35;
  reg [2:0] stateWriteMem;
  reg [31:0] _RAND_8;
  wire  _T_241;
  wire [2:0] _GEN_36;
  wire [2:0] _GEN_37;
  wire  _T_242;
  wire  _T_244;
  wire  _T_245;
  wire [2:0] _GEN_38;
  wire [2:0] _GEN_40;
  wire  _T_247;
  wire  _T_251;
  wire  _T_252;
  wire  _T_253;
  wire [2:0] _GEN_41;
  wire  _GEN_42;
  wire [2:0] _GEN_45;
  wire  _T_258;
  wire  _T_265;
  wire  _T_266;
  wire  _T_267;
  wire [2:0] _GEN_47;
  wire  _GEN_48;
  wire [2:0] _GEN_50;
  wire  _T_269;
  wire  _T_279;
  wire  _T_280;
  wire  _T_281;
  wire  _GEN_51;
  wire  _GEN_52;
  wire  _GEN_53;
  wire  _GEN_54;
  assign m_axi_gmem_AWVALID = _GEN_53;
  assign m_axi_gmem_AWADDR = 64'h20;
  assign m_axi_gmem_AWSIZE = 3'h5;
  assign m_axi_gmem_AWLEN = 8'h0;
  assign m_axi_gmem_AWBURST = 2'h1;
  assign m_axi_gmem_AWID = 8'h0;
  assign m_axi_gmem_AWLOCK = 1'h0;
  assign m_axi_gmem_AWCACHE = 4'h0;
  assign m_axi_gmem_AWPROT = 3'h0;
  assign m_axi_gmem_AWQOS = 4'h0;
  assign m_axi_gmem_WVALID = _GEN_52;
  assign m_axi_gmem_WDATA = {{507'd0}, value};
  assign m_axi_gmem_WSTRB = 64'h0;
  assign m_axi_gmem_WLAST = _T_253;
  assign m_axi_gmem_BREADY = _GEN_51;
  assign m_axi_gmem_ARVALID = 1'h0;
  assign m_axi_gmem_ARADDR = 64'h0;
  assign m_axi_gmem_ARSIZE = 3'h0;
  assign m_axi_gmem_ARLEN = 8'h0;
  assign m_axi_gmem_ARBURST = 2'h0;
  assign m_axi_gmem_ARID = 8'h0;
  assign m_axi_gmem_ARLOCK = 1'h0;
  assign m_axi_gmem_ARCACHE = 4'h0;
  assign m_axi_gmem_ARPROT = 3'h0;
  assign m_axi_gmem_ARQOS = 4'h0;
  assign m_axi_gmem_RREADY = 1'h0;
  assign s_axi_control_AWREADY = 1'h1;
  assign s_axi_control_WREADY = _GEN_16;
  assign s_axi_control_BVALID = _GEN_16;
  assign s_axi_control_BRESP = 2'h0;
  assign s_axi_control_ARREADY = 1'h1;
  assign s_axi_control_RVALID = _GEN_28;
  assign s_axi_control_RDATA = {{30'd0}, _T_189};
  assign s_axi_control_RRESP = 2'h0;
  assign _T_102 = stateSlaveWrite == 3'h0;
  assign _GEN_1 = s_axi_control_AWVALID ? 3'h1 : stateSlaveWrite;
  assign _GEN_3 = _T_102 ? _GEN_1 : stateSlaveWrite;
  assign _T_103 = stateSlaveWrite == 3'h1;
  assign _T_105 = _T_102 == 1'h0;
  assign _T_106 = _T_105 & _T_103;
  assign _GEN_4 = s_axi_control_WVALID ? {{480'd0}, s_axi_control_WDATA} : regDataReceived;
  assign _GEN_5 = s_axi_control_WVALID ? 1'h0 : regDone;
  assign _GEN_6 = s_axi_control_WVALID ? 3'h3 : _GEN_3;
  assign _GEN_8 = _T_106 ? _GEN_4 : regDataReceived;
  assign _GEN_9 = _T_106 ? _GEN_5 : regDone;
  assign _GEN_10 = _T_106 ? _GEN_6 : _GEN_3;
  assign _T_109 = stateSlaveWrite == 3'h3;
  assign _T_113 = _T_103 == 1'h0;
  assign _T_114 = _T_105 & _T_113;
  assign _T_115 = _T_114 & _T_109;
  assign _GEN_11 = s_axi_control_BREADY ? 3'h7 : _GEN_10;
  assign _GEN_15 = _T_115 ? _GEN_11 : _GEN_10;
  assign _T_163 = stateSlaveWrite == 3'h7;
  assign _T_170 = _T_109 == 1'h0;
  assign _T_171 = _T_114 & _T_170;
  assign _T_172 = _T_171 & _T_163;
  assign _GEN_16 = _T_172 ? 1'h0 : 1'h1;
  assign _GEN_18 = _T_172 ? 3'h0 : _GEN_15;
  assign _T_175 = regDataReceived[0];
  assign _T_183 = stateSlaveRead == 3'h0;
  assign _GEN_21 = s_axi_control_ARVALID ? 3'h2 : stateSlaveRead;
  assign _GEN_23 = _T_183 ? _GEN_21 : stateSlaveRead;
  assign _T_184 = stateSlaveRead == 3'h2;
  assign _T_186 = _T_183 == 1'h0;
  assign _T_187 = _T_186 & _T_184;
  assign _GEN_55 = {{1'd0}, regDone};
  assign _T_189 = _GEN_55 << 1'h1;
  assign _GEN_24 = s_axi_control_RREADY ? 3'h7 : _GEN_23;
  assign _GEN_27 = _T_187 ? _GEN_24 : _GEN_23;
  assign _T_191 = stateSlaveRead == 3'h7;
  assign _T_195 = _T_184 == 1'h0;
  assign _T_196 = _T_186 & _T_195;
  assign _T_197 = _T_196 & _T_191;
  assign _GEN_28 = _T_197 ? 1'h0 : 1'h1;
  assign _GEN_29 = _T_197 ? 3'h0 : _GEN_27;
  assign _T_208 = regFlagStart == 1'h0;
  assign _T_209 = regStart & _T_208;
  assign _T_211 = value == 5'h1d;
  assign _T_213 = value + 5'h1;
  assign _T_214 = _T_213[4:0];
  assign _GEN_30 = _T_211 ? 5'h0 : _T_214;
  assign _GEN_31 = _T_209 ? _GEN_30 : value;
  assign _GEN_32 = _T_209 ? 1'h1 : regFlagStart;
  assign _T_218 = value > 5'h0;
  assign _T_220 = value < 5'h19;
  assign _T_221 = _T_218 & _T_220;
  assign _GEN_34 = _T_221 ? _GEN_30 : _GEN_31;
  assign _T_229 = value >= 5'h19;
  assign _T_231 = _T_221 == 1'h0;
  assign _T_232 = _T_231 & _T_229;
  assign _GEN_35 = _T_232 ? 1'h1 : regStartWriting;
  assign _T_241 = stateWriteMem == 3'h0;
  assign _GEN_36 = regStartWriting ? 3'h4 : stateWriteMem;
  assign _GEN_37 = _T_241 ? _GEN_36 : stateWriteMem;
  assign _T_242 = stateWriteMem == 3'h4;
  assign _T_244 = _T_241 == 1'h0;
  assign _T_245 = _T_244 & _T_242;
  assign _GEN_38 = m_axi_gmem_AWREADY ? 3'h5 : _GEN_37;
  assign _GEN_40 = _T_245 ? _GEN_38 : _GEN_37;
  assign _T_247 = stateWriteMem == 3'h5;
  assign _T_251 = _T_242 == 1'h0;
  assign _T_252 = _T_244 & _T_251;
  assign _T_253 = _T_252 & _T_247;
  assign _GEN_41 = m_axi_gmem_WREADY ? 3'h6 : _GEN_40;
  assign _GEN_42 = _T_253 ? 1'h1 : _T_245;
  assign _GEN_45 = _T_253 ? _GEN_41 : _GEN_40;
  assign _T_258 = stateWriteMem == 3'h6;
  assign _T_265 = _T_247 == 1'h0;
  assign _T_266 = _T_252 & _T_265;
  assign _T_267 = _T_266 & _T_258;
  assign _GEN_47 = m_axi_gmem_BVALID ? 3'h7 : _GEN_45;
  assign _GEN_48 = _T_267 ? 1'h1 : _T_253;
  assign _GEN_50 = _T_267 ? _GEN_47 : _GEN_45;
  assign _T_269 = stateWriteMem == 3'h7;
  assign _T_279 = _T_258 == 1'h0;
  assign _T_280 = _T_266 & _T_279;
  assign _T_281 = _T_280 & _T_269;
  assign _GEN_51 = _T_281 ? 1'h0 : _GEN_48;
  assign _GEN_52 = _T_281 ? 1'h0 : _T_253;
  assign _GEN_53 = _T_281 ? 1'h0 : _GEN_42;
  assign _GEN_54 = _T_281 ? 1'h1 : _GEN_9;
 always @(posedge ap_clk) begin
    if (ap_rst_n) begin
      regStart <= 1'h0;
    end else begin
      regStart <= _T_175;
    end
    if (ap_rst_n) begin
      regDone <= 1'h0;
    end else begin
      if (_T_281) begin
        regDone <= 1'h1;
      end else begin
        if (_T_106) begin
          if (s_axi_control_WVALID) begin
            regDone <= 1'h0;
          end
        end
      end
    end
    if (ap_rst_n) begin
      regDataReceived <= 512'h0;
    end else begin
      if (_T_106) begin
          regDataReceived <= {{480'd0}, s_axi_control_WDATA};
        end
      end
    end
    if (ap_rst_n) begin
      stateSlaveWrite <= 3'h0;
    end else begin
      if (_T_172) begin
      end else begin
        if (_T_115) begin
          if (s_axi_control_BREADY) begin
            stateSlaveWrite <= 3'h7;
          end else begin
            if (_T_106) begin
                stateSlaveWrite <= 3'h3;
              end else begin
                if (_T_102) begin
                  if (s_axi_control_AWVALID) begin
                    stateSlaveWrite <= 3'h1;
                  end
                end
              end
            end else begin
              if (_T_102) begin
                end
              end
            end
          end
        end else begin
          if (_T_106) begin
            end else begin
              if (_T_102) begin
                end
              end
            end
          end else begin
            if (_T_102) begin
              end
            end
          end
        end
      end
    end
    if (ap_rst_n) begin
      stateSlaveRead <= 3'h0;
    end else begin
      if (_T_197) begin
      end else begin
        if (_T_187) begin
          if (s_axi_control_RREADY) begin
            stateSlaveRead <= 3'h7;
          end else begin
            if (_T_183) begin
              if (s_axi_control_ARVALID) begin
                stateSlaveRead <= 3'h2;
              end
            end
          end
        end else begin
          if (_T_183) begin
            end
          end
        end
      end
    end
    if (ap_rst_n) begin
      value <= 5'h0;
    end else begin
      if (_T_221) begin
        if (_T_211) begin
          value <= 5'h0;
        end else begin
          value <= _T_214;
        end
      end else begin
        if (_T_209) begin
          if (_T_211) begin
            value <= 5'h0;
          end else begin
            value <= _T_214;
          end
        end
      end
    end
    if (ap_rst_n) begin
      regFlagStart <= 1'h0;
    end else begin
      if (_T_209) begin
        regFlagStart <= 1'h1;
      end
    end
    if (ap_rst_n) begin
      regStartWriting <= 1'h0;
    end else begin
      if (_T_232) begin
        regStartWriting <= 1'h1;
      end
    end
    if (ap_rst_n) begin
      stateWriteMem <= 3'h0;
    end else begin
      if (_T_267) begin
        if (m_axi_gmem_BVALID) begin
          stateWriteMem <= 3'h7;
        end else begin
          if (_T_253) begin
            if (m_axi_gmem_WREADY) begin
              stateWriteMem <= 3'h6;
            end else begin
              if (_T_245) begin
                if (m_axi_gmem_AWREADY) begin
                  stateWriteMem <= 3'h5;
                end else begin
                  if (_T_241) begin
                    if (regStartWriting) begin
                      stateWriteMem <= 3'h4;
                    end
                  end
                end
              end else begin
                if (_T_241) begin
                  end
                end
              end
            end
          end else begin
            if (_T_245) begin
              end else begin
                if (_T_241) begin
                  end
                end
              end
            end else begin
              if (_T_241) begin
                end
              end
            end
          end
        end
      end else begin
        if (_T_253) begin
          end else begin
            if (_T_245) begin
              end else begin
                stateWriteMem <= _GEN_37;
              end
            end else begin
            end
          end
        end else begin
          if (_T_245) begin
            end else begin
            end
          end else begin
          end
        end
      end
    end
  end
endmodule
Tags (3)
Re: [BD 41-237] Bus Interface property ID_WIDTH does not match between /master_bridge_0/s_axi(1) and /m_axi_interconnect_M00_AXI/s00_couplers/auto_cc/M_AXI(8)
This is a known issue for AXI ID width larger than "1" in 2017.1_sdx/2017.2_sdx, Version 4 DSAs. It has been resolved in Version 5 DSAs.
To work around it, do following steps:
1)  Get a local copy of “ocl_block_utils.tcl” from SDx installation area
    cp <SDX_TOOL_INSTALLATION_PATH>/lin64/SDx/2017.1/Vivado/scripts/ocl/ocl_block_utils.tcl .
2)  Modify the local copy of “ocl_block_utils.tcl”
    modify line 941-944:
    set m_bridge_s_id_width 1
    if { $num_conn >= 1 } {
      set m_bridge_s_id_width [expr ([::tcl::mathfunc::int [::tcl::mathfunc::ceil [expr [::tcl::mathfunc::log $num_conn] / [::tcl::mathfunc::log 2]]]] + 1)]
change above 4 lines as follow:
    set m_bridge_s_id_width 8
    #if { $num_conn >= 1 } {
    #  set m_bridge_s_id_width [expr ([::tcl::mathfunc::int [::tcl::mathfunc::ceil [expr [::tcl::mathfunc::log $num_conn] / [::tcl::mathfunc::log 2]]]] + 1)]
Please note, "m_bridge_s_id_width" should match the AXI ID width in your RTL code.
Since module AdderAxi has AXI ID width "8", so, "m_bridge_s_id_width" is set to "8".
3)  Set environment variable SDACCEL_OCL_BLOCK_UTILS so that SDx will pick up your modified file instead of one from the installation area. Please use absolute path such as:
setenv SDACCEL_OCL_BLOCK_UTILS <your local absolute path>/ocl_block_utils.tcl
4) Run your flow
