Observer 662ldd
Can multiple kernels share the same data?
I am developing a database accelerator using U200. I have a very large index (about 20G) that should be read by all of the kernels. I would like to put it in the DDRs of the card and my question is: 1. how to make all the kernels have access to this index? Should I just set the buffers of the index as their input respectively? If so, will the host write the index to the global memory only once or not? 2. The database query execution has multiple iterations. In each iteration the index remains unchanged but other input changes. How can I tell the host not to write the index to global memory again and again? BTW, I am using RTL kernels.
Re: Can multiple kernels share the same data?
Multiple kernels can access to same buffer however single buffer size can not exceed 4GB.
In your case, the large dataset has to be split into several buffers.
Observer 662ldd
Thanks for your reply! I can split the index into multiple buffers easily but I still wonder:
Is there any example of multiple kernels sharing same buffers?
Besides, in my case, I want the shared buffers stay in the global memory while other input buffers change in each iteration of my algorithm. Can this be done?
Here is an example of multiple kernels sharing one buffer: https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/rtl_kernel/rtl_vadd_2kernels
Regarding your second question, the answer is yes. Say that you have buffer A and B on device ddr. At the begining, host writes data to both A and B. Then A may keep unchanged and host can re-write B as your wish.
