Visitor yancoo
Cannot find the correct device in emulation mode using JNI
I'm trying to test examples ( https://github.com/Xilinx/Applications/tree/2017.1/GZip ), that is OK with host .exe. I need to run Java program using JNI to loadLibrary host .so,  then i make host .so by modifying utility/rules.mk, but this leads to the failure to find the correct device.
[root@localhost xil_gzip]# ls -l libxil_gzip.so
-rwxr-xr-x. 1 root root 1646712 Aug 21 16:52 libxil_gzip.so
[root@localhost xil_gzip]# XCL_EMULATION_MODE=sw_emu java XilGzip example.txt
platform Name: Xilinx
Vendor Name : Xilinx
Found Platform
Found Device=xilinx:pcie-hw-em:7v3:1.0
XCLBIN File Name: gZip_1cu
INFO: Importing xclbin/gZip_1cu.sw_emu.xilinx_pcie-hw-em_7v3_1_0.xclbin
ERROR: xclbin/gZip_1cu.sw_emu.xilinx_pcie-hw-em_7v3_1_0.xclbin xclbin not available please build
The correct device is "xilinx:kcu1500:4ddr-xpr:4.0", but the Found Device is "xilinx:pcie-hw-em:7v3:1.0" which not exist, so error happen because the .xclbin file can not be found.
By the way, i have created emconfig.json with 'emconfigutil --platform xilinx:kcu1500:4ddr-xpr:4.0 --nd 1', and i have  writen another cpp code to call function of host .so with dlopen/dlsym, that is also OK to find the correct device, but it does not work when using JNI.
Is the emconfig.son file not processed normally in emulation mode using JNI? Any help is appreciated. thanks.
Re: Cannot find the correct device in emulation mode using JNI
Did you choose right target device while you generate your host exe? looks like your host is try to allocate a 7v3 board but not ku1500 board.
BTW, please use latest version of GZIP and SDAccel, 2017.1 was released over a year ago.
Visitor yancoo
@allyzThank you for you reply. I have compared the latest version with 2017.1,and the difference between them is very small.
In order to better locate the problem, I submit the source code as attachments.
Using JNI has problems whether it is emulation mode or hardware system. We can reproduce problems as following processes.
In emulation mode:
cd xil_gzip
javac src.java/XilGzip.java -d .
javah -jni -classpath . -o src/XilGzip_JNI.h XilGzip
make all TARGETS=sw_emu DEVICES=xilinx:kcu1500:4ddr-xpr:4.0
XCL_EMULATION_MODE=sw_emu java XilGzip LICENSE.txt
The error result in emulation mode:
In hw mode:
make clean
make all DEVICES=xilinx:kcu1500:4ddr-xpr:4.0
The error result in hw mode:
However, using cpp code to call xil_gzip .so is all right.
g++ src.test/test_call_so.cpp -o test_call_so -ldl
# run in emulation mode
XCL_EMULATION_MODE=sw_emu ./test_call_so LICENSE.txt
# run in hw mode
So no matter what, using JNI to call xil_gzip .so will definitely cause problems, do you need to do something special to solve?
Best Regards.
You mentioned cpp code works find, but I don't think Java JNI is officially supported at our flow. need follow up from Runtime team.
