Observer jsyoo1117
Cannot profile kernel properly.
Hello, following picture is a screenshot of profiling the vision/watermark example of SDAccel, ver. 2018.2
I'm running the example on a 2018.2 SDx due to compatability issues.
The question is: Isn't the 'compute unit' part (the three lines below) supposed to come AFTER the blue apply_watermark line, 4th from the bottom?
Or at least, AFTER the clEnqueueNDRangeKernel queue at the second from top?
I believe that 1) There is a misunderstanding of how profiling works/how kernel enqueues are done, or 2) I've done something wrong when setting the profiling.  What might this case be?
Help would be appreciated Thank you.
linker option: --profile_kernel data:all:all:all checked 'Execute Profiling' and 'Stall Profiling' at hardware function settings(bottom left corner of screen)
回复: Cannot profile kernel properly.
I think they are supposed to be at the same time. There seems something wrong.
You may try newer version or other target mode to see any difference if possible.
brucey
