Observer boydun
Clarification on High Performance Matrix Multiplication Example
As a newbie to SDAccel, I was hoping to clarify some parts of the SDAccel High Performance Matrix Multiplication example that I was browsing through. Specifically, I was hoping for elaboration on sections of https://github.com/Xilinx/SDAccel_Examples/blob/51416734fd694773a2ab4991f027e5c78e09c9a8/acceleration/high_perf_mat_mult/src/high_perf_mat_mult.cpp.
I wasn't too sure how the parallel_rows, parallel_columns, and depth variables factored into the overall multiplication process and how they allowed for optimization. In addition, it seems like the file I linked to is the testbench corresponding to kernelSgemm_0, which contains the actual CL code. Is that true? And if so, how can I access the CL-specific code?
Peter
Re: Clarification on High Performance Matrix Multiplication Example
Hi boydun,
The host code in this exaple both calls the kernel, and acts as a bit of a test bench to compare the results.
So the kernel is created (loaded):
xcl_world world = xcl_world_single();
cl_program program = xcl_import_binary(world, "high_perf_mat_mult0"); // compute programs
cl_kernel kernelSgemm_0 = xcl_get_kernel(program, "kernelSgemm_0"); // compute kernel
and then based on the inputs to the program memory in the host is setup for the matrix. And that memory is filled with values.
Pointers to these memorys are setup:
cl_mem_ext_ptr_t d_a_ext;
cl_mem_ext_ptr_t d_b_ext;
cl_mem_ext_ptr_t d_d_ext;
cl_mem_ext_ptr_t d_c_ext;
Some work is done to point them to the respective banks for specific cards
and then the buffers are created, and copied to the device
d_a = clCreateBuffer(world.context, CL_MEM_READ_ONLY | CL_MEM_EXT_PTR_XILINX, sizeof(short) * num_of_rows * depth, &d_a_ext, &err);
assert(err == CL_SUCCESS);
d_b = clCreateBuffer(world.context, CL_MEM_READ_ONLY | CL_MEM_EXT_PTR_XILINX, sizeof(short) * (num_of_cols/2) * depth , &d_b_ext, &err);
d_d = clCreateBuffer(world.context, CL_MEM_READ_ONLY | CL_MEM_EXT_PTR_XILINX, sizeof(short) * (num_of_cols/2) * depth , &d_d_ext, &err);
d_c = clCreateBuffer(world.context, CL_MEM_WRITE_ONLY | CL_MEM_EXT_PTR_XILINX, sizeof(short) * num_of_rows * num_of_cols, &d_c_ext, &err);
std::cout << "Copying Buffers to device...." << std::endl;
xcl_memcpy_to_device(world,d_a,h_a,sizeof(short) * num_of_rows * depth);
xcl_memcpy_to_device(world,d_b,h_b,sizeof(short) * (num_of_cols/2) * depth);
xcl_memcpy_to_device(world,d_d,h_d,sizeof(short) * (num_of_cols/2) * depth);
And finally it's enqueued and run and the results are wainted on.:
err = clEnqueueTask(world.command_queue, kernelSgemm_0, 0, NULL, &ks_0_event);
err = clFinish(world.command_queue);
Then the results are readback, checked, and some details of how fast it ran are generated.
the .xo file that is also in the directory is the actual kernel. All the above is host code. For the high performance example we don't have the CL code on the github as I can tell.
Does that answer your question? Or was there a section you wanted to know more about from this example?
Evan
If at first you don't succeed, try redefining success?
