Observer fpga2017
Emulation-HW failed for KCU1500 board
I'm trying to use the KCU1500 board, the board has been installed in my computer successfully, and I'm running the very simple example of vadd following UG1021, I had run Emulation-SW successfully, but when I ran Emulation-HW, I met this problem:
INFO: [VPL 60-839] Read in kernel information from file 'kernel_info.dat'.
INFO: [VPL 60-895]    Target platform: /home/gg/Xilinx/SDx/2017.4/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm
INFO: [VPL 60-423]   Target device: xilinx_kcu1500_dynamic_5_0
INFO: [VPL 60-251]   Hardware accelerator integration...
ERROR: [VPL 60-399] vivado failed, please see log file for detail: '/home/gg/workspace/ug1021_20180725/vadd/Emulation-HW/_xocc_link_krnl_vadd/_vpl/ipi/vivado.log'
ERROR: [VPL 60-806] Failed to finish platform linker
ERROR: [XOCC 60-398] vpl failed
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
makefile:80: recipe for target 'krnl_vadd.xclbin' failed
make: *** [krnl_vadd.xclbin] Error 1
Can anybody give me some suggestion? Thank you very much!
回复: Re: Re: Emulation-HW failed for KCU1500 board
SDx 2017.4 supports the following OS:
• Windows 7 and 7 SP1 Professional (64-bit) (SDSoC only)
• Windows 10 Professional (64-bit) (SDSoC only)
• Linux Support
○ Red Hat Enterprise Workstation/Server 7.2-7.3 (64-bit)
○ Red Hat Enterprise Workstation 6.7, and 6.8 (SDSoC only)
○ Red Hat Enterprise Workstation 6.9 (64-bit)
○ CentOS 6.9, CentOS 7.3 (64-bit) (SDAccel)
○ Ubuntu Linux 16.04.2 LTS (64-bit)
Would you please try on a supported Ubuntu version?
回复: Emulation-HW failed for KCU1500 board
Any more details in
'/home/gg/workspace/ug1021_20180725/vadd/EmulationHW/_xocc_link_krnl_vadd/_vpl/ipi/vivado.log'?
Observer fpga2017
I'm attaching it, please check, thank you very much!
回复: Re: Emulation-HW failed for KCU1500 board
The following error is seen from the log.
/usr/bin/ld: xsim.dir/emu_wrapper_behav/obj/xsim_6.lnx64.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
What OS is the tool running on?
Observer fpga2017
I'm using Ubuntu 4.13, the complete information is here:
Linux version 4.13.0-46-generic (buildd@lcy01-amd64-002) (gcc version 7.2.0 (Ubuntu 7.2.0-8ubuntu3.2)) #51-Ubuntu SMP Tue Jun 12 12:36:29 UTC 2018
• Linux Support
Observer fpga2017
Re: Re: Re: Emulation-HW failed for KCU1500 board
Good suggestion, I'll do it, thanks.
Observer fpga2017
I reinstalled the OS and it works! Thanks a lot!
I still have one more question, in ug1238, it requires about 30 packages (such as: ocl-icd-libopencl1, opencl-headers, ... etc.) installed by 'apt-get install' command, so do I have to install these packages one by one? Or it will be installed automatically when I install the OS? Thanks!
Re: Re: Re: Re: Emulation-HW failed for KCU1500 board
Hi, @fpga2017 ,
Please start a new thread for the new question and close the resolved thread.
Observer fpga2017
OK.
Hi, @fpga2017 ,
Thank you for your cooperation.
