Error when using LAPC: connect_bd_net requires at least two pins/ports, or one pin/port and a net
In SDx2018.2, adding Lightweight AXI Protocol Checkers (LAPC):
Krnl_GA_LDCLFLAGS+=--dk protocol:Krnl_GA_1:all
I am getting the following error when building:
INFO: [VPL 60-251] Hardware accelerator integration... Creating Vivado project and starting FPGA synthesis. WARNING: [VPL 60-1142] Unabled to read data from
'<PROJECT_PATH>/_x/link/vivado/output/generated_reports.log',
generated reports will not be copied. ===>The following messages were generated while creating FPGA bitstream.
Log file:<PROJECT_PATH>/_x/link/vivado/vivado.log : ERROR: [VPL 41-701] connect_bd_net requires at least two pins/ports, or one pin/port and a net ERROR: [VPL 5-4] Error: running connect_bd_net.
ERROR: [VPL 60-773] In '<PROJECT_PATH>/_x/link/vivado/vivado.log', caught Tcl error:
ERROR: [Common 17-39] 'connect_bd_net' failed due to earlier errors.
I used the same LAPC flags in SDx v2017.4 without problems.
I need LAPC to analyze  kernel interfaces, but as shown above FPGA build fails.
Any help on this?
Leo
Best,
L30nardo SV
Re: Error when using LAPC: connect_bd_net requires at least two pins/ports, or one pin/port and a net
Hi, @leonardo.solis ,
Which platform are you using?
Could you upload the vivado.log?
