Visitor jhanani
Errors in SDAccel example while compiling with clang
I am new to this field. I tried to compile the OpenCL example provided by the SDAccel in clang and  I got the following errors:
/opt/Xilinx/SDx/2017.4.op/lnx64/tools/clang/bin/clang -I /opt/Xilinx/SDx/2017.4.op/runtime/include/1_2 -S -emit-llvm -o conv.ll -x cl krnl_convolve.cl
krnl_convolve.cl:48:9: error: unknown type name 'uint2'
typedef uint2 bus_t;
krnl_convolve.cl:121:6: error: use of undeclared identifier 'size_t'; did you mean 'sizeof'?
for(size_t i = 0; i < M(IMAGE_WIDTH*IMAGE_HEIGHT); i++) {
krnl_convolve.cl:121:20: error: use of undeclared identifier 'i'
krnl_convolve.cl:121:53: error: use of undeclared identifier 'i'
krnl_convolve.cl:125:22: error: use of undeclared identifier 'i'
bus_to_short(input[i], input_buf);
krnl_convolve.cl:128:7: error: use of undeclared identifier 'size_t'; did you mean 'sizeof'?
for(size_t y = 0; y < FILTER_HEIGHT-1; y++) {
krnl_convolve.cl:128:21: error: use of undeclared identifier 'y'
krnl_convolve.cl:128:42: error: use of undeclared identifier 'y'
krnl_convolve.cl:130:8: error: use of undeclared identifier 'size_t'; did you mean 'sizeof'?
for(size_t x = 0; x < REG_WIDTH - B; x++) {
krnl_convolve.cl:130:22: error: use of undeclared identifier 'x'
krnl_convolve.cl:130:41: error: use of undeclared identifier 'x'
krnl_convolve.cl:131:14: error: use of undeclared identifier 'y'
line_reg[y][x] = line_reg[y][x+B];
krnl_convolve.cl:131:17: error: use of undeclared identifier 'x'
krnl_convolve.cl:131:31: error: use of undeclared identifier 'y'
krnl_convolve.cl:131:34: error: use of undeclared identifier 'x'
krnl_convolve.cl:134:8: error: use of undeclared identifier 'size_t'; did you mean 'sizeof'?
for(size_t j = 0; j < B; j++) {
krnl_convolve.cl:134:22: error: use of undeclared identifier 'j'
krnl_convolve.cl:134:29: error: use of undeclared identifier 'j'
krnl_convolve.cl:135:14: error: use of undeclared identifier 'y'
line_reg[y][(REG_WIDTH - B) + j] = line_buf[y][j + B*(i %...
I included CL/cl.h in the opencl file and added the include files as well, but it didn't work for me. I  would like to know if there is any other library that can be added to solve this errors?
Re: Errors in SDAccel example while compiling with clang
This flow is not officially supported.
brucey
brucey
Visitor jhanani
Is it possible to generate CFG for OpenCL example provided by Xilinx SDAccel?
