Visitor asimroy
I need help to change the default emulation device in SDaccel(SDx version 2018.2) through the command line and the gui.
Re: I need help to change the default emulation device in SDaccel(SDx version 2018.2) through the command line and the gui.
Hi, @asimroy ,
You can modify the platform in "Application Project Settings"
In xocc command, --platform option is used to specify the platform you selected.
Example: xocc -t hw_emu --platform xilinx_vcu1525_dynamic_5_2 --save-temps ...
Visitor asimroy
I am unable to find how to change the default platform in the User Guide. Can you point me to a specific section where it is located?
Thank you.
Hi, @asimroy ,
