Visitor skotti
Interpret output of hardware emulation
Hello!
Could you please describe, what output of hardware emulation in SDAccel environment mean and why it runs so long?
INFO: [SDx-EM 22] [Wall clock time: 11:46, Emulation time: 1.54685 ms] Data transfer between kernel(s) and global memory(s)
BANK0          RD = 3.750 KB               WR = 262.812 KB
BANK1          RD = 0.000 KB               WR = 0.000 KB
BANK2          RD = 0.000 KB               WR = 0.000 KB
BANK3          RD = 0.000 KB               WR = 0.000 KB
INFO: [SDx-EM 22] [Wall clock time: 11:51, Emulation time: 1.73858 ms] Data transfer between kernel(s) and global memory(s)
BANK0          RD = 4.250 KB               WR = 295.438 KB
Each such bunch of four lines - means one launch of the kernel code or one predefined bunch of memory transfer or something else? I am pretty sure that hardware emulation is slower than real because of statistics or something like that? Is it true or there are some other reasons. And also what these Emulation time: 1.73858 ms relates to? Definitely I am waiting more than 2 ms for this output.
This is a basic stuff but this output is not described anywhere and I want to be sure that I understand what it shows.
Tags (3)
Re: Interpret output of hardware emulation
@skotti,
Check this link and see if it helps:
https://forums.xilinx.com/t5/SDAccel/what-does-it-mean-by-the-msg-of-INFO-SDx-EM-22/td-p/785735
--Syed
@skotti,
--Syed
