Visitor skotti
New version of SDAccel 2018.2 performs internal transformations
Hello!
I have this bunch of code:
#pragma OPENCL EXTENSION cl_khr_fp64 : enable
__kernel void kernel0(__global double *A, __global double *B, int tsteps, int n, int c0)
    int b0 = get_group_id(0);
    int t0 = get_local_id(0);
    local double local_A[30]  __attribute__((xcl_array_partition(cyclic,2,1)));
    local double local_B[30]  __attribute__((xcl_array_partition(cyclic,2,1)));
#pragma nounroll
    for (int i = 0; i < 30; i++) {
    	local_A[i] = A[i];
        local_B[i] = B[i];
    for (int c1 = 1; c1 < n - 1; c1 += 1) {
    	local_B[c1] = (0.33333 * ((local_A[c1 - 1] + local_A[c1]) + local_A[c1 + 1]));
#pragma nounroll
        A[i] = local_A[i];
    	B[i] = local_B[i];
__kernel void kernel1(__global double *A, __global double *B, int tsteps, int n, int c0)
      A[c1] = (0.33333 * ((B[c1 - 1] + B[c1]) + B[c1 + 1]));
I mapped A and B to different banks (0, 1) in the host code.
SDAccel process this kernel and instead of reporting three kernels with II=1 creates five (!!) cycles with II=1. Why does this happen? In 2018.1 I didn't have such problems.
Re: New version of SDAccel 2018.2 performs internal transformations
Could you try placing the pipeline attribute before the loop and see if behavior changes?
__attribute__((xcl_pipeline_loop))
for () {
If II still can not meet the target, you may open the corresponding HLS project and use analysis view to identify the root cause.
