Visitor peffers
Passing RTL defines through xocc tool
It seems like this must be possible but I can't seem to find the right options.
I'd like to pass some preprocessor defines through xocc to vivado. xocc -D doesn't seem to get passed through and I can't find the right --xp option.
Can someone point me in the right direction?
回复: Passing RTL defines through xocc tool
To pass Vivado properties, you can use the following --xp parameter.
vivado_prop:<object_type>.<object_name>.<prop_name>
e.g.
--xp vivado_prop:run.synth_1.{STEPS.SYNTH_DESIGN.ARGS.MORE OPTIONS}={-verilog_define name=value}
