SDAccel 2018.2, hardware emulation, sysmalloc: Assertion failed
I installed SDAccel 2018.2 on a fresh Ubuntu 16.04.5.
I installed the dependencies.
I can run software emulation, but when I try the hardware emulation, I got this error:
Loading: '../vadd.xclbin'
INFO: [SDx-EM 01] Hardware emulation runs simulation underneath. Using a large data set will result in long simulation times. It is recommended that a small dataset is used for faster execution. This flow does not use cycle accurate models and hence the performance data generated is approximate.
test_simple.exe: malloc.c:2394: sysmalloc: Assertion `(old_top == initial_top (av) && old_size == 0) || ((unsigned long) (old_size) >= MINSIZE && prev_inuse (old_top) && ((unsigned long) old_end & (pagesize - 1)) == 0)' failed.
I tried with the C hello world, and simple burst read and write examples.
SDAccel 2017.4 is working fine.
Re: SDAccel 2018.2, hardware emulation, sysmalloc: Assertion failed
I nailed down something, my xilinx_aws-vu9p-f1_dynamic_5_0 platform compiled on a previous installation doesn't work anymore. Choosing kcu1500 works.
Hi, @xil_tour ,
Did you install the correct package for Ubantu as the below thread discussed:
https://forums.xilinx.com/t5/SDAccel/Do-I-have-to-install-all-the-Linux-packages-listed-in-ug1238/m-p/877400
Yes I followed the recommendations from ug1238, trying the big apt from your link gave me:
The following additional packages will be installed:
libjpeg-turbo8-dev libjpeg8-dev libopencv-core2.4v5 libtbb2
The following packages will be REMOVED:
libjpeg62-dev
The following NEW packages will be installed:
libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libopencv-core-dev libopencv-core2.4v5 libtbb2 libtiff5-dev
0 upgraded, 7 newly installed, 1 to remove and 0 not upgraded.
But the crash is still here.
Ubuntu calls it
bash crashed with SIGABRT in __GI___waitpid()
If I uncheck host debug and kernel debug, I got this error:
*** invalid %N$ use detected ***
