Visitor chonhuang
SDAccel Error: dlopen of ***/sw_emu/device0/binary_0/dltmp is failed Please check undefined symbols in the kernel
device : xilinx_u250_xdma_201830_1
Loading: 'QEX.hw.xilinx_u250_xdma_201830_1.xclbin'
ERROR: dlopen of /home/sdx_worspace/QEX/bin/.run/pid/sw_emu/device0/binary_0/dltmp is failed Please check undefined symbols in the kernel
ERROR: failed to load xclbin
./host/QEX_tb.cpp:102 Error calling cl::Program program(context, devices, bins, NULL, &err), error code is : -44
I could't get the location infomation of which cause this error.
Who can give me some advice:  which report/log shuold read,  which part of code is dubious ?
Re: SDAccel Error: dlopen of ***/sw_emu/device0/binary_0/dltmp is failed Please check undefined symbols in the kernel
How to reproduce the issue?
Visitor chonhuang
command line:XCL_EMULATION_MODE=sw_emu ./host xclbin/matrix_inverse_adjugate_method.sw_emu.xilinx_u250_xdma_201830_1.xclbin
all source code in attachment。
build command same to SDAccel Example in github
There may be some errors in the xclbin.
Better to debug the Makefile carefully or try to build the .xo/hw_emu by step to check the Makefile and kernel API.
回复: SDAccel Error: dlopen of ***/sw_emu/device0/binary_0/dltmp is failed Please check undefined symbols in the kernel
Can you attach the log file for the provided test case?
For the original error you posted (looks to be based on a different design)
It looks to me the .xclbin generated when TARGET is set to 'hw' is loaded rather than 'sw_emu'.
