Observer calibra
SDAccel fail with only vector ports
The following error appear:
Loading: '../binary_container_1.xclbin'
ERROR: Missing AXI Slave (control) port for kernel krnl_vadd
ERROR: program is nullptr
When I compile this simple code.
extern "C" {
void krnl_vadd( const int* a, const int* b, nt* c)
#pragma HLS INTERFACE m_axi depth=512 port=a offset=slave bundle=gmem
#pragma HLS INTERFACE m_axi depth=512 port=b offset=slave bundle=gmem
#pragma HLS INTERFACE m_axi depth=512 port=c offset=slave bundle=gmem
#pragma HLS INTERFACE s_axilite port=return bundle=control
int arrayA[10];
readA: for (int j = 0 ; j < 10 ; j++) arrayA[j] = a[j];
vadd_wrteC: for (int j = 0 ; j < 10 ; j++) c[j] = arrayA[j] + b[j];
A dummy port solves the problem:
extern "C" {
void krnl_vadd( const int* a,const int* b, int* c, const int dummy)
#pragma HLS INTERFACE s_axilite port=dummy bundle=control
    int arrayA[10];
TEST PASSED
Re: SDAccel fail with only vector ports
As for I know, it's because of axi implementation.
When a kernel starts the AXI transaction (read/write from/to memory), some basic information (i.e. address) is required.
So, your kernel needs to have a axi-lite port (like your dummy port) to get those information from the host.
I hope this can answer your question.
Haeseung
