SDLAccel RTL Kernel with slave AXI4 port
Hi All,
I'm porting an existing accellerator card IP core into the SDAccel enviroment.
The issue that I have is that it has a salve AXI4-MM interface for a data port that needs to be conected to the PCIe XDMA engine.It also has an AXI4-MM interface for conection to external memory and hte IP core controles the DDR4 data transfers. The PCIe XDMA is a streaming data interface for a number of job descriptors which a max size of 16K each;
I Know that the docs state that all AXI4 interfaces should be masters or streaming, howrver it also implies that an AXI4-MM SLAVE can be used.
Has anyone ever done this or know if it is possible. The target platform is theVCU1525 card with default DSA setup, although this may need modifications.
Can anyone provide any help with this
Mark N
回复: SDLAccel RTL Kernel with slave AXI4 port
Iris
Thanks, so all I need to do is the inclusion of the SRL interconnects on the AXI4 memory mapped interface from the XDAM.
This is exactly what I was hoping for.
Mark
Mark,
XDMA IP should have Memory Map Interface used as Master port  which can connect with your slave port
regards
Iris
Iris
Mark
