SdAccle 2017.1 + KCU1500: enqueueReadBuffer from Device to Host fails with "ERROR: Failed to sync 1024/-1 bytes"
During the execution of test on the host, observing error similar to this in some cases.
Initially saw this only bigger buffer size. However it has become more frequent and is now happening even at 1 KB
Debugging showed that this is during rad back of device data into Host. This code has worked realizably so far
q.enqueueReadBuffer(buffer_c, CL_TRUE, 0, vector_size_bytes, result_krnl.data());
What could be causing this? Has anyone seen this?
1. Host memory being corrupted?
2. Device (FPGA) being corrupted/
3. Timing issue on Device (FPGA)?
4. Data Type (int32 vs int?)
5. Buffer size?
Prasad
Re: SdAccle 2017.1 + KCU1500: enqueueReadBuffer from Device to Host fails with "ERROR: Failed to sync 1024/-1 bytes"
Hello
I have not seen any suggestion for my original post. Unfortunately this issue still exists
Please let me know if anyone has any suggestions to work around or fix this
Prasad
hi @pkuruganti
would help if you can provite small testcase and/or :
    1. dmesg log, OS info, driver version info, PCI bus info, what board, maybe are what all OpenCL platforms on the system.
    2. did you try new SDAccel 2017.2 or older and whta's the status etc
    3. can you check that your drivers, if need to force reinstall: from xbinst board package: ./install.sh -f yes -k yes
thank you !
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Hi Herve
I am installing 2017.2,
However the issue is not on all designs, which indicates that the drivers, board and OS, PCIE slot are working
Board is =>  KCU1500
PCIE is reporting => Gen3, x8
 LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM unknown, Latency L0 unlimited, L1 unlimited
   ClockPM- Surprise- LLActRep- BwNot-
OS (from uname -r) : 4.1.15.pnotify
SDAccel Version => 2017.1
OpenCL:
The OpenCL code has beffers defined for inputs and outputs to kernel. Kenel is a simple MAC (multiply-add). The issue seems to happen when the buffer is filled  (result of MAC), i.e readback from kernel
Hope this helps
Prasad
Prasad
BTW: If you have setup, I may be able to send a small test case, that you can build and try on your side
Hello
Installing KCU1500 board package from SDAccel 2017.2 is giving following error.
It works fine with 2017.1 version (Messages from both runs are copied below)
With SDAccel 2017.2:
sudo /home/tools/xilinx/SDAccel/2017.2/bin/xbinst -f xilinx:kcu1500:4ddr-xpr:4.0 -d kcu1500_setup/
****** xbinst v2017.2_sdx (64-bit)
  **** SW Build 1972098 on Wed Aug 23 11:34:38 MDT 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
ERROR: [XBINST 60-705] No device was found that matches 'xilinx:kcu1500:4ddr-xpr:4.0'. The supported devices are:
ERROR: [XBINST 60-587] Failed to add a device: specified platform xilinx:kcu1500:4ddr-xpr:4.0 is not found
With SDAccel 2017.1:
sudo /opt/Xilinx/SDx/2017.1/bin/xbinst -f xilinx:kcu1500:4ddr-xpr:4.0 -d kcu1500_setup/
****** xbinst v2017.1_sdx (64-bit)
  **** SW Build 1915620 on Thu Jun 22 17:54:59 MDT 2017
INFO: [XBINST 60-895]    Target platform: /opt/Xilinx/SDx/2017.1/platforms/xilinx_kcu1500_4ddr-xpr_4_0/xilinx_kcu1500_4ddr-xpr_4_0.xpfm
INFO: [XBINST 60-267] Packaging for PCIe...
INFO: Adding section using: 'xilinx_kcu1500_' (2052429 Bytes)
INFO: [XBINST 60-268] Packaging for PCIe...COMPLETE
INFO: [XBINST 60-667] xbinst has successfully created a board installation directory at /workspaces/kcu1500_setup.
hi @pkuruganti
looks like the DSA is not installed? can you run
xocc --list_xdevices
note: the result would be the DSA names matching the subdirectories from the YOURSDXINSTALL/platforms directory (but this dir includes the SDSoC platforms too)
Also yes, you should be able to PM me with your testcase
- Hervé
SIGNATURE:
Looks like 2017.2 has changed the Device name in "emcconfig.jason" while the name selected in tool is same. Due to this compiles generated in 2017.1 are  compatible with 2017.2 and vice versa. Is this a new bug?
Prasad
diff -b /workspaces/test_sdaccel/gmac_cpp_int16_fill/System/emconfig.json emconfig.json
5c5
<         "ToolVersion": "2017.1"
>         "ToolVersion": "2017.2"
12c12
<                         "Name": "xilinx:kcu1500:4ddr-xpr:4.0",
>                         "Name": "xilinx_kcu1500_4ddr-xpr_4_0",
The device is list is shown below. So the name is listed as the one used by 2017.1 tool chain.
Can you please advise on next steps here
Prasad
/home/tools/xilinx/SDAccel/2017.2/bin/xocc --list_xdevices
xilinx:adm-pcie-ku3:2ddr:3.3
xilinx:xil-accel-rd-ku115:4ddr-xpr:3.3
xilinx:xil-accel-rd-ku115:4ddr-xpr:4.0
xilinx:zc706:linux-uart:1.0
xilinx:adm-pcie-8k5:2ddr:3.3
xilinx:adm-pcie-8k5:2ddr:4.0
xilinx:adm-pcie-7v3:1ddr:3.0
xilinx:adm-pcie-ku3:2ddr-xpr:4.0
xilinx:adm-pcie-ku3:2ddr-xpr:3.3
Hi - Hervé
Can you please help resolving this?
Prasad
