Simultaneous r/w on multiple memory banks
with 4 DDR banks, is it possible to have like 2 reads and 2 write at the same time ?
The kernel global bandwidth example shows only 1 read and 1 write at a time.
Re: Simultaneous r/w on multiple memory banks
I managed to use the 4 banks at the same time, but not with the kernel global bandwidth example, which may have a problem.
extern "C" {
void sobel(uint512_dt *inimg, uint512_dt *outimg, uint512_dt *inimg2, uint512_dt *outimg2) {
#pragma HLS INTERFACE m_axi port=inimg  offset=slave bundle=gmem0
#pragma HLS INTERFACE m_axi port=outimg  offset=slave bundle=gmem1
#pragma HLS INTERFACE m_axi port=inimg2  offset=slave bundle=gmem2
#pragma HLS INTERFACE m_axi port=outimg2  offset=slave bundle=gmem3
#pragma HLS INTERFACE s_axilite port=inimg  bundle=control
#pragma HLS INTERFACE s_axilite port=outimg bundle=control
#pragma HLS INTERFACE s_axilite port=inimg2  bundle=control
#pragma HLS INTERFACE s_axilite port=outimg2 bundle=control
#pragma HLS INTERFACE s_axilite port=return bundle=control
	uint512_dt local_buffer;
	uint512_dt local_buffer2;
	loop_read: for(int line = 0; line < 64*64;  line++) {
#pragma HLS PIPELINE
		local_buffer = inimg[line];
		outimg[line] = local_buffer;
		local_buffer2 = inimg2[line];
		outimg2[line] = local_buffer2;
	return;
All these DDR banks can be used independently.
How can I achieve that modifying the example ?
#define NDDR_BANKS 4
kernel __attribute__ ((reqd_work_group_size(1,1,1)))
void bandwidth(__global uint16  * __restrict input0,
               __global uint16  * __restrict output0,
               __global uint16  * __restrict input1,
               __global uint16  * __restrict output1,
               ulong num_blocks)
    __attribute__((xcl_pipeline_loop))
    for (ulong blockindex = 0; blockindex < num_blocks; blockindex++) {
        uint16 temp0 = input0[blockindex];
        output0[blockindex] = temp0;
        uint16 temp1 = input1[blockindex];
        output1[blockindex] = temp1;
It should already be 2 read + 2 write at the same time, but for some reason, it's not the case.
Is the DDR mapping changed in config.mk file?
Add the appropriate changes for LDCLFLAGS in config.mk file
Vishnu
I see no config.mk file in the project folder.
Can you explain "appropriate changes" please ?
Hi @xil_tour,
you can find config.mk file in the following path :
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/kernel_to_gmem/kernel_global_bandwidth
Based on number of banks you want to use, you can set ddr_banks variable and corresponding banks.
Vishnu
Can't I change that after having imported the project in SDx ?
Hi @xil_tour,
Under the Hardware Functions, right click the kernel and select "Edit XOCC Options",
if you are using 1DDR then add    :  --sp bandwidth_1.m_axi_gmem0:DDR[0]
if you are using 2DDR then add  : --sp bandwidth_1.m_axi_gmem0:DDR[0] --sp bandwidth_1.m_axi_gmem0:DDR[1]
According based on number of DDR's you can add to XOCC Options.
Vishnu
I already have this in the "XOCC Options" :
--sp bandwidth_1.m_axi_gmem0:bank0 --sp bandwidth_1.m_axi_gmem1:bank1 --sp bandwidth_1.m_axi_gmem2:bank2 --sp bandwidth_1.m_axi_gmem3:bank3
Are DDR[0] and bank0 valid aliases ?
Hi @xil_tour,
yes, DDR[0] and bank0 are valid aliases.
Vishnu
extern "C" {
	return;
