Visitor asimroy
Unable to find emconfig.json when tried running SDAccel from command line
While running SDx 2018.2 from the command line. I am getting an Error : 'CRITICAL WARNING: [SDx-EM 08-0] Unable to find emconfig.json. Using default device "xilinx:pcie-hw-em:7v3:1.0" '
My emconfig.json file is in the same directory as the host application.
回复: Unable to find emconfig.json when tried running SDAccel from command line
Did you run 'emconfigutil' command to create the emulation configuration file for the target platform?
Also ensure you set XCL_EMULATION_MODE to sw_emu or hw_emu to change the application execution to emulaiton mode.
Visitor asimroy
I have set the XCL_EMULATION_MODE to sw_emu. The emconfig file is generated and is found from the .cpp program. However, I want to run this .cpp from a python shell using Boost. The code runs, but it is not able to find the emconfig.json file there. I searched online, but could not find a suitable answer to this question, as it should be seen from the python terminal if it is seen from g++, as both share the same PWD.
Thank you.
Hi @asimroy
please check from the host code with c system calls what is the pwd and the file, and the env variable. it looks the sub-shell from python is not what you are expecting.
good luck
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
