change device type for project make
[ Edited ]
In nimbix platform, the device ku115 has changed from 3.2 to 3.3
The default make command " make TARGETS=sw_emu all " failed due to the device change.
I tried to change the device type by using this command:
emconfigutil --xdevice 'xilinx:adm-pcie-ku3:2ddr-xpr:3.3' --nd 1
It still failed.
Can anyone help?
thx
Re: change device type for project make
Hi @sl_cgi
You will need to do a git pull to update the repository in your working directory.
Best,
-Dutch
If your are using following gitRepo, so I would suggest to pull the new changes from GitRepo. It has been updated for new Devices.
https://github.com/Xilinx/SDAccel_Examples
Or, you can directly  default Device in your board.mk (sample)
https://github.com/Xilinx/SDAccel_Examples/blob/master/utility/boards.mk
DEVICES:= xilinx:xil-accel-rd-ku115:4ddr-xpr:3.3
Or you can change the default DSA while running make command:
make TARGETS=sw_emu all DEVICES=xilinx:xil-accel-rd-ku115:4ddr-xpr:3.3
If you have some Device filtering in your Example Makefile ( Couple of GitHub Example has this so good to check), you should update Example Makefile to list new DSA as in supported list. Search for *_DEVICES and update it.
[ Edited ]
thanks for your help.
I downloaded the latest version from Git. Now the device is correct.
But there is another error for " make TARGETS=hw all" for project of "SDAccel_Examples/getting_started/basic/kernel_global_bandwidth/"
Please see the detailed error msg and the vivado log file is attached as well.
What could be the problem?
Just clean up the project and made a build. Now it works.
Any idea why?
