Newbie sheldon99
compile error Can't find XPM_FIFO_SYNC
 I am using Vivado 18.2
When compiling a project to target the AWS F1, I get a message: “can’t find XPM_FIFO_SYNC”
This works when I don’t use block design. Now I have the code in a Module in the Block Design and it gives this error.
Thank you for your help.
回复: compile error Can't find XPM_FIFO_SYNC
When using the Project Mode, the Vivado tool will parse the files added to the project and will automatically recognize the XPMs. However, when using XPMs in the Non-Project mode you must issue the auto_detect_xpm command prior to reading or importing source files.
In addition, the macro is in lower case: "xpm_fifo_sync". You can refer to Vivado Language Templates or UG974 for instantiation template.
Newbie sheldon99
Re: compile error Can't find XPM_FIFO_SYNC
Thank you very much, that worked.
Case Closed
Newbie sheldon99
Thank you very much
