Visitor alterade2
disable warning message
How can I disable the warning message "double precision constant requires cl_khr_fp64, casting to single precision" ?
Voyager
Voyager
Re: disable warning message
Hey @alterade2,
You can disable the warning by removing or commenting out the #warning (or #error) directive from the source code.
But most likely you want to either replace the double precision constant by a single precision one or alternatively enable the cl_khr_fp64 extension (before the first double precision constant) to support double precision.
#pragma OPENCL EXTENSION cl_khr_fp64 : enable
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Visitor alterade2
Thank you for your instructions!  I wondered if the tool can do that so that I don't need to  replace the double precision constant by a single precision one manually.
