Visitor ntender
error message during hw_emu simulation when using XPM in design
I am trying to simulate my design in hw_emu mode, but when I run the executable I get the error message below.  I only started getting this message when I added a XPM memory macro to my design.  Previously I was using an inferred memory and everything worked great.  But when I replaced the inferred memory with the XPM memory, I ran into this problem.  I would prefer to use the XPM memory if possible.  The code stub for the instantiation of my memory is also below.
I am running SDAccel version 2018.2.  Please let me know if you need any additional information.
Thanks, Neil
XCL_EMULATION_MODE=hw_emu ./host
Found Platform
Platform Name: Xilinx
XCLBIN File Name: mydesign
INFO: Importing xclbin/mydesign.hw_emu.xilinx_vcu1525_dynamic_5_1.xclbin
Loading: 'xclbin/mydesign.hw_emu.xilinx_vcu1525_dynamic_5_1.xclbin'
[libprotobuf ERROR google/protobuf/message_lite.cc:121] Can't parse message of type "response_packet_info" because it is missing required fields: size
INFO: [SDx-EM 01] Hardware emulation runs simulation underneath. Using a large data set will result in long simulation times. It is recommended that a small dataset is used for faster execution. This flow does not use cycle accurate models and hence the performance data generated is approximate.
../common//utility/check.mk:60: recipe for target 'check_hw_emu_xilinx_vcu1525_dynamic_5_1_check' failed
make: *** [check_hw_emu_xilinx_vcu1525_dynamic_5_1_check] Error 141
   // Instantiate RAM
   xpm_memory_sdpram #(
     .ADDR_WIDTH_A            ( ADDRESS_WIDTH       ),
     .ADDR_WIDTH_B            ( ADDRESS_WIDTH       ),
     .AUTO_SLEEP_TIME         ( 0                   ),
     .BYTE_WRITE_WIDTH_A      ( DATA_WIDTH          ),
     .CLOCKING_MODE           ( "independent_clock" ),
     .ECC_MODE                ( "no_ecc"            ),
     .MEMORY_INIT_FILE        ( "none"              ),
     .MEMORY_INIT_PARAM       ( ""                  ),
     .MEMORY_OPTIMIZATION     ( "true"              ),
     .MEMORY_PRIMITIVE        ( "block"             ),
     .MEMORY_SIZE             ( 2**ADDRESS_WIDTH    ),
     .MESSAGE_CONTROL         ( 0                   ),
     .READ_DATA_WIDTH_B       ( DATA_WIDTH          ),
     .READ_LATENCY_B          ( 1                   ),
     .READ_RESET_VALUE_B      ( "0"                 ),
     .USE_EMBEDDED_CONSTRAINT ( 0                   ),
     .USE_MEM_INIT            ( 1                   ),
     .WAKEUP_TIME             ( "disable_sleep"     ),
     .WRITE_DATA_WIDTH_A      ( DATA_WIDTH          ),
     .WRITE_MODE_B            ( "no_change"         )
   input_channel_buffer_ram_inst (
     .dbiterrb            (             ),
     .doutb               ( ram_dob     ),
     .sbiterrb            (             ),
     .addra               ( src_addr_i  ),
     .addrb               ( ram_addrb   ),
     .clka                ( io_clk_i    ),
     .clkb                ( io_clk_i    ),
     .dina                ( src_data_i  ),
     .ena                 ( 1'b1        ),
     .enb                 ( 1'b1        ),
     .injectdbiterra      ( 1'b0        ),
     .injectsbiterra      ( 1'b0        ),
     .regceb              ( 1'b1        ),
     .rstb                ( io_rst_i    ),
     .sleep               ( 1'b0        ),
     .wea                 ( src_we_i    )
Re: error message during hw_emu simulation when using XPM in design
Hi, @ntender ,
Could you provide RTL kernel's xo file and host code to reproduce the design?
