Visitor youad
printf not working with with SDAccel 2018.2?
Hi all,
I just switched to SDAccel 2018.2 from 2017.2. I found that the printf in OpenCL seems no longer working. It just prints 0 for all variables. For example:
printf("this number is %d.\n",100);
 in a .cl file will produce "this number is 0" in the terminal.
When I compile the same code using 2017.2, the printf works normally. Anyone knows why is this? Is this some sort of bug of 2018.2?
回复: printf not working with with SDAccel 2018.2?
Hi, @youad ,
The printf issue in SW-Emulation has been reproduced in SDx 2018.2, and it is planned to be fixed in SDx 2018.3.
Visitor youad
Re: printf not working with with SDAccel 2018.2?
Anyone using the latest version of SDAccel?
In which run did you observe this result? SW emulation, HW emulation or system?
This shouldn't be a common issue. Can you share the test case?
Hi, @youad ,
The issue can be seen in SDx 2018.2 SW-Emu stage and has been reflected to the developer.
Visitor youad
I encounter this issue when running SW emulation. I tried several previous projects of mine (work well in 2017) and none can printf correctly. The projects are compiled from command line.
If it is not a issue in SDAccel 2018, then probably it is some compiler flags issue? I can share with you the terminal output if you want to look at it. Could you also run some code in 2018 and see if it is a common issue?
Hi, @youad ,
