xcl2.hpp cannpt be found
There are three files in my folder.
main.cpp
kernel.cpp
params.h
The main file includs the params.h file.
In the params.h file it includes
"#include "xcl2.hpp"
#include <CL/cl.h>
#include <CL/opencl.h>
When compiling it says
params.h:6:10: fatal error: 'xcl2.hpp' file not found
#include "xcl2.hpp"
But from the out put of the make I can see the -I includes the "
../../../libs/xcl2
", where is the xcl2.hpp located.
/opt/Xilinx/SDx/2018.2.EA2236721/bin/xcpp -Wall -O0 -g -std=c++14 -I ./include -I ../../../libs/xcl2/ -I../../../libs/xcl2 -I/opt/Xilinx/SDx/2018.2.EA2236721/runtime/include/1_2 -O0 -g -Wall -fmessage-length=0 -fopenmp  ./src/main.cpp src/k_nn.cpp src/pca_index.cpp  src/common.cpp src/csv_parser.cpp ../../../libs/xcl2/xcl2.cpp -o pcaf_host -lOpenCL -lpthread -lrt -lstdc++ -lflann -lgsl -L/opt/Xilinx/SDx/2018.2.EA2236721/runtime/lib/x86_64 -L./lib -L/opt/Xilinx/SDx/2018.2.EA2236721/runtime/lib/x86_64 -L/opt/Xilinx/SDx/2018.2.EA2236721/lib/lnx64.o -lOpenCL -pthread
Why?
Please help.
Re: xcl2.hpp cannpt be found
Could you try using absolute path in -I and see if it works?
Hi, @mathmaxsean ,
Does the absolute path method suggested by yunl work for you?
