Visitor gknowles
xocc fails to make .xclbin for Emulation-HW
During the final stages of compilation for Emulation-HW I get the following error:
/opt/Xilinx/SDx/2018.1/bin/xocc -t hw_emu --platform /home/gknowles/openCL/aws/aws_fpga_repo/SDAccel/aws_platform/xilinx_aws-vu9p-f1_4ddr-xpr-2pr_4_0/xilinx_aws-vu9p-f1_4ddr-xpr-2pr_4_0.xpfm --save-temps --report estimate -l --nk top_chip_bin:1 -g --messageDb binary_container_1.mdb --xp misc:solution_name=_xocc_link_binary_container_1 --xp param:prop:kernel.top_chip_bin.kernel_flags="-std=c++98" -o"binary_container_1.xclbin" binary_container_1/top_chip_bin.xo
****** xocc v2018.1 (64-bit)
**** SW Build 2188600 on Wed Apr 4 18:39:19 MDT 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: [XOCC 60-897] Reading --xp value from platform: param:compiler.lockFlowCritSlackThreshold=0
WARNING: [XOCC 60-642] Invalid parameter name: prop:kernel.top_bin.kernel_flags
INFO: [XOCC 60-629] Linking for hardware emulation target
INFO: [XOCC 60-895] Target platform: /home/gknowles/openCL/aws/aws_fpga_repo/SDAccel/aws_platform/xilinx_aws-vu9p-f1_4ddr-xpr-2pr_4_0/xilinx_aws-vu9p-f1_4ddr-xpr-2pr_4_0.xpfm
INFO: [XOCC 60-423] Target device: xilinx:aws-vu9p-f1:4ddr-xpr-2pr:4.0
INFO: [XOCC 60-1032] Extracting DSA to ./.Xil/xocc-11819-carmen/xilinx_aws-vu9p-f1_4ddr-xpr-2pr_4_0
INFO: [XOCC 60-251] Hardware accelerator integration...
ERROR: [XOCC 60-399] vivado failed, please see log file for detail: '/home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi/vivado.log'
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
makefile:88: recipe for target 'binary_container_1.xclbin' failed
make: *** [binary_container_1.xclbin] Error 1
The log file is:
# Vivado v2018.1 (64-bit)
# SW Build 2188600 on Wed Apr 4 18:39:19 MDT 2018
# IP Build 2185939 on Wed Apr 4 20:55:05 MDT 2018
# Start of session at: Mon May 28 12:54:26 2018
# Process ID: 11968
# Current directory: /home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi
# Command line: vivado -mode batch -notrace -source /home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi/ipirun.tcl -messageDb /home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi/vivado.pb
# Log file: /home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi/vivado.log
# Journal file: /home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi/vivado.jou
source /home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_ipi/ipirun.tcl -notrace
Sourcing kernel info from: ./map.tcl
key "scripts_dir" not known in dictionary
while executing
"dict get $config_info scripts_dir"
invoked from within
"source [dict get $config_info scripts_dir]/_vivado_params.tcl"
(file "/home/gknowles/openCL/opencl_top_chip_bin/Emulation-HW/_xocc_link_binary_container_1/impl/build/hw_em/binary_container_1/sv/binary_container_1_i..." line 229)
INFO: [Common 17-206] Exiting Vivado at Mon May 28 12:54:34 2018...
Any ideas?
Visitor gknowles
Re: xocc fails to make .xclbin for Emulation-HW
Problem was solved by moving to the latest v5 dynamic dsa. The chip now compiles.
Visitor gknowles
Hi gknowles, can you mark yourself as a the solution. It sounds like updating the dsa was the needed resolution.
If at first you don't succeed, try redefining success?
