Why SDSoC does not generate the Vivado project?
I cannot find the Vivado project in the ipi folder.
I have selected the Generate bitstream and the Estimate performance, but after building the project in either Debug and Release options, I cannot find the .xpr file to be opened by Vivado.
Does anyone know why?
Cerilet
Re: Why SDSoC does not generate the Vivado project?
Which release and platform are you using?
Hi @tshui,
I'm using 2016.4 right now.
If both the Generate Bitstream and Estimate Performance options are selected, the Estimate Performance option
appears to be taking precedence and the Vivado project for creating the bitstream is not being generated. After
the build completed, did the IDE display Performance Estimation results? If yes, then this is what happened.
Uncheck the "Estimate Performance" option, build the project again and check to see if the Vivado Project was
created. On the console there should be messages about creating address map, block diagram, synthesis, etc.
