A problem is difficult to solve about accelerating compiler, please help me to solve it. Thank you very much
I am compiling a project about the algorithm predict. This project of algorithm has been compiled normally without using hardware acceleration.  I have encountered a function to speed up the compilation error when I use the "Toggle SW/HW function" to accelerate this function, The function which I want to hardware accelerate and error is  shown as follows. Please help me how to solve it? Any suggestions are very grateful!
function:
int ttest(float data_0[use_rows], float data_1[use_rows], float data_2[1], float data_3[1])
// ttest 检验
float dif[use_rows];
float dif_sd[use_rows];
float sd = 0.0;
float mean_0 = 0.0;
// 计算总体的差值
for (int i = 0 ; i < count_0; i ++)
dif[i] = data_0[i] - data_1[i];
// 计算平均收益
for (int i = 0 ; i < count_0 ; i ++)
mean_0 += dif[i];
mean_0 = mean_0 / (count_0);
// 计算标准差
dif_sd[i] = (dif[i] - mean_0) * (dif[i] - mean_0);
sd += dif_sd[i];
sd = sd / ((count_0 - 1 ) * count_0);
sd = pow(sd,0.5);
// string result = to_string(mean_0) + "," + to_string(sd);
for (int i=0; i<1; i++)
data_2[i]= mean_0;
data_3[i] = sd;
return 1;
The error:
Creating block diagram (BD)
Creating top.bd.tcl
Rewrite caller functions
Compile caller rewrite file D:/QFtest/test/Debug/_sds/swstubs/main.cpp
D:/QFtest/test/Debug/_sds/swstubs/main.cpp:102:99: error: expected identifier before ')' token
int _p0_ttest_1_noasync(float data_0[2000], float data_1[2000], float data_2[1], float data_3[1], );
D:/QFtest/test/Debug/_sds/swstubs/main.cpp: In function 'int main(int, char**)':
D:/QFtest/test/Debug/_sds/swstubs/main.cpp:138:69: error: too few arguments to function 'int _p0_ttest_1_noasync(float*, float*, float*, float*, int)'
_p0_ttest_1_noasync(data_use_0,data_use_1,data_use_2,data_use_3);
D:/QFtest/test/Debug/_sds/swstubs/main.cpp:102:5: note: declared here
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++ -c D:/QFtest/test/Debug/_sds/swstubs/main.cpp -ID:/QFtest/test/src -ID:/QFtest/test/src -Wall -O0 -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -I E:/XilinX/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I E:/XilinX/Vivado/2018.2/include -o D:/QFtest/test/Debug/_sds/swstubs/main.o'
sds++ log file saved as D:/QFtest/test/Debug/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
Re: A problem is difficult to solve about accelerating compiler, please help me to solve it. Thank you very much
@sharpmddr,
Can you provide info on how your hardware function is being called? From the logs, it looks like the call you're making is not terminated correct based upon this line:
Steve
=======================Hardware Accelerate Head File===========================
#include <string>
#include <iostream>
#include <fstream>
#include <sstream>
#include <math.h>
using namespace std;
const int rows = 40000;
const int columns = 5;
const int use_rows = 2000;
extern int count_0; // Reference global variable count_0
int ttest(float data_0[use_rows], float data_1[use_rows], float data_2[1], float data_3[1]);
========================Main Function=============================================
int count_0; //set a global counter
int main(int argc, char *argv[])
       unsigned long long s = sds_clock_counter();//clock_counter_start
      for (int label = 0; label <36; label ++)
           count_0 = 0;
           float data_use_0[use_rows];
           float data_use_1[use_rows];
           float data_use_2[1];
           float data_use_3[1];
           process_data();  //this function will change the value of the global counter(count_0)
           ttest(data_use_0,data_use_1,data_use_2,data_use_3);
           cout << data_use_2[0] << endl;
           cout << data_use_3[0] << endl;
       unsigned long long e = sds_clock_counter();//clock_counter_end
         printf("\t Clock cycle: %llu\n", e - s);
         printf("\t Time: %.4f [sec]\n", (e - s)*1.0/sds_clock_frequency());
       return 0;
I am not able to reproduce the issue with a clean workspace targeting the ZCU102. I am looking at the swstubs file created by SDx, and I am not seeing any missing information.
Have you tried cleaning the project and rebuilding?
Looks to be some files might not have been in-sync during build.
Steve
