Newbie hale2bopp
AXI_DMA_SIMPLE_WAIT run on hardware hangs when adding a function to hardware
We are using a Zedboard evaluation kit and Xilinx SDx to run a compression deduplication stream for a school project, accelerated on hardware. We were able to get the stream set up and running in software, and synthezisable in hardware according to Vivado HLS, and also build the function as a hardware function in Xilinx SDSoC.
Our hardware function is hanging in cf_wait around the axi_simple_dma_wait. We used the following pragmas before our function which is reading data from the SDCard on the board into an array. The functin foo is defined within foo.cpp which is a source file.
#pragma SDS mem_attribute(input[0:LENGTH])
#pragma SDS data data_copy(input[0:LENGTH])
#pragma SDS data access_pattern(input::SEQUENTIAL)
void foo(input[LENGTH], foobar1, foobar2){
Any idea why this could be happening and how to debug this?
Re: AXI_DMA_SIMPLE_WAIT run on hardware hangs when adding a function to hardware
Hi @hale2bopp
1. mem_attribute pragma which you have written is wrong. Correct sytax is,
#pragma SDS data mem_attribute(ArrayName:contiguity)
Contiguity: Must be either PHYSICAL_CONTIGUOUS or NON_PHYSICAL_CONTIGUOUS.The default value is NON_PHYSICAL_CONTIGUOUS
2. #pragma SDS data copy(ArrayName[:]) -> you have written it as data_copy which is not correct
here is link to pragma guide https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2018_2/ug1253-sdx-pragma-reference.pdf
Best Regards,
Nutan
