Observer marie-laurie
Building of CHaiDNN
I am trying to build CHaiDNN from source using the SDx GUI. I just want to make sure I did everything correctly:
  • Does the SDx GUI build include the "build CHaiDNN Hardware from Source" and the "build CHaiDNN Software from Source" ?
Thank you in advance,
ML
Re: Building of CHaiDNN
Hi @marie-laurie,
Build from SDx gui for sure it builds the HW, but I'm not sure about the SW. I suggest you to go first over the Makefile and see what steps this process performs (after generating the .so files, .bit files, and boot files, the Makefile copies everything inside the SD_card directory, same for SW with all the *.elf files), then it will be much more easy for you to go with the GUI and perform manually all the missing steps if any.
/* Don't forget to give kudos and/or accept as a solution */
Thank you for your answer, I will look into that !
