olivetree
CHaiDNN - PoolTop function does not show toggle hw/sw
I am trying to build the CHaiDNN (https://github.com/Xilinx/CHaiDNN) from source with SDx GUI following the instructions given here:
https://github.com/Xilinx/CHaiDNN/blob/master/docs/BUILD_USING_SDX_GUI.md
In step 26, I suppose to select PoolTop and XiDeconvTop to toggle hw/sw for hardware implementation of these two functions, but 1). when I right-click on the functions in outline window, it did not show the toggle hw/sw option in the menu; 2) I went to the project editor window where all the hardware functions suppose to be listed there, and there is none listed as hardware function 3). in the Add Hardware Function window, these functions are not listed as candidates either.
What do I do to add these two function as hardware functions?
Olive
Tags (3)
olivetree
Never mind! it came out with Add Hardware Function, just it took very long time to list out the matching items, I guess my machine is slow...
Olive
