daichong
CHaiDNN build failed
When I compile the ChaiDNN project according to the provided steps, I get the following error. How can I solve this problem?
daichong
The above figure is an error when running under the windows system. Now this picture is running under the linux system, but also the same error, how to solve it?
vandenplas
I'm starting to use the CHaiDNN, also . Did you get it build ok? Any tips? Many thanks
My plan is to interface it with a camera. Do you have any recommendations?
neutrinoxy
Hello @vandenplas,
I think you didn't have to post three messages in different subjects for the same question.
Could you, please, upload some logs or give more details about why you failed to build the CHaiDNN project ?
Best regards.
vandenplas
I think the build works if I only have one of the examples included in the build (this isn't made clear in the instructions)
The example read an image from a file. I would like to take my image from a camera, using say the revision platform. Is that something you've got any experience with?
daichong
I have successfully compiled the ChaiDNN. My thoughts are the same as yours. I also want to take my image from a camera,but I still haven't started to do this thing. I hope to keep in touch with you. This is my email: 1124203793@qq.com
gusuduxiou
I got the same error as you say above.how did you solved it?Can you give me sone tips?Thanks!!!
daichong
SDS++ Compiler→Symbols,When you add symble "__SDSOC",notice that there are two horizontal lines connected together, not one.
daichong
Delete redundant .cpp files in software/example leaving only one
gusuduxiou
it works. thanks again.
xqrabc
Does you use SDx 2018.2 compire OK?
