kardec
[CHaiDNN] concat modules disconnected in block design
Hi guys,
I've followed the "build from source" guide to create the hardware in Vivado.
This block design is the result:
As you can see, both concat modules are disconnected. Their inputs are disconnected.
I guess this is an error, am I right?
How can I solve that?
Thanks in advance.
tanders
There's nothing in the Tcl that connects these input ports.  I'm not that familiar w/ this design yet, but these are likely used as inputs down the flow.  Continue on, as you can create the complete the rest of the design as it stands.
I got the same block diagram working through this and was able to create the DSA
