Cannot create new SDSoC project
I'm not able to create a new SDSoC project on ubuntu 16.04 with SDSoC Version 2015.4 (64 bit)
When clicking on "create new SDSoC project" nothing happens. The log file shows me:
!SESSION 2016-08-02 18:26:44.065 -----------------------------------------------
eclipse.buildId=2015.4
java.version=1.8.0_45
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ui 4 0 2016-08-02 18:27:07.628
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
        at com.xilinx.sdsoc.ui.wizard.SDSProjectMainComposite.validatePlatformFile(SDSProjectMainComposite.java:226)
        at com.xilinx.sdsoc.ui.wizard.SDSProjectMainComposite.selectValidPlatform(SDSProjectMainComposite.java:122)
        at com.xilinx.sdsoc.ui.wizard.SDSProjectMainComposite.<init>(SDSProjectMainComposite.java:74)
        at com.xilinx.sdsoc.ui.wizard.SDSProjectWizardPage.createControl(SDSProjectWizardPage.java:33)
        at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
        at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
        at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1182)
        at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1241)
        at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1238)
        at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1227)
        at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
        at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1225)
        at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:915)
        at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:428)
        at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:628)
        at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
        at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
        at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3742)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3363)
        at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)!SESSION 2016-08-02 18:26:44.065 -----------------------------------------------
!STACK 0
There seems to be a related problem with different installation folders (https://forums.xilinx.com/t5/SDSoC-Development-Environment/Can-t-create-an-SDSoC-Project/td-p/706841), but I use the standard folders:
[18:28:05]/opt/Xilinx/SDSoC/2015.4/bin$ pwd
[18:28:06]/opt/Xilinx/SDSoC/2015.4/bin$ ./sdsoc
An my workspace is located at in:
/home/sbuschjaeger/Desktop/sdsoc-workspace
I already tried to install a newer version of SDSoC, but there seems to be a problem with the download. Does anybody have an idea how to get 2015.4 running?
Hi sbuschjaeger,
Which platform are you trying to make a project for? Is it a custom platform or one of the defaults (zc702/zed/etc...)?
Sam
why do you want 2015.4 ?? 2016.2 SDSoC is released!
@sskalick I dont get that farI can select "SDSoC Project" in the "New Project" wizard. But when I click on "next" nothing happens and the error message is generate in the log file.
@trenz-al I have 2015.4 installed and the web installer for 2016.2 is not working at the moment because "some file are missing on the server". But I'm currently downloading the whole 7GB iso file which takes ages...
Hi sbuschjaeger,
Can you select File -> New -> SDSoC Project from the menu bar. Does the New Project Wizard open? Or do you get an error?
Sam
Hi @sskalick
Nothing happens. Same error.
Hi ,
Im not really sure what the problem is, but 2015.4 only officially supported Ubuntu Linux 14.04.2 LTS (64-bit). Heres a link to the release notes.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug1185-sdsoc-release-notes.pdf
Sam
If you are not using a new workspace, try that in case the one you're using became corrupted. Make sure
the workspace is not in the SDSoC installation folder and you are not starting sdsoc from within an installation folder.
Confirm you have write permission in the workspace.
If you continue to see problems, you can try enabling diagnostic messages. Before using File > New > SDSoC Project,
open the Windows > Preferences dialog, expand the Xilinx SDSoC entry, click on Log Information, and select Log Level TRACE.
Try File > New > SDSoC Project and see if the SDSoC Log view in the lower right hand corner contains error messages
and post them to the forum.
SDSoC 2016.2 officially supports Ubuntu 14.04.3 LTS http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1185-sdsoc-release-notes.pdf
and you might possibly run into issues using Ubuntu 16.04.
