Visitor dawn.paul
ChaiDNN build error
Following error is got while building Chaidnn for zcu104. I have followed the following link
Building file: ../src/software/swkernels/xi_eltwiseadd_top.cpp
Invoking: SDS++ Compiler
sds++ -sds-hw XiConvolutionTop  /home/ml1/guruprasad/dawn/chai2/CHaiDNN/design/conv/src/xi_convolution_top.cpp -clkid 1 -hls-tcl  /home/ml1/guruprasad/dawn/chai2/CHaiDNN/design/conv/scripts/config_core.tcl -sds-end -D__SDSOC -D__CONV_ENABLE__ -D__DSP48E2__ -D__SYNTHESIS__ -D__DECONV_ENABLE__ -D__POOL_ENABLE__ -Wall -O0 -g -I/home/ml1/guruprasad/dawn/chai2/CHaiDNN/SD_Card/opencv/arm64/include -I/home/ml1/guruprasad/dawn/chai2/CHaiDNN/SD_Card/protobuf/arm64/include -I/home/ml1/guruprasad/dawn/chai2/CHaiDNN/SD_Card/cblas/arm64/include -I/home/ml1/guruprasad/dawn/chai2/CHaiDNN/SD_Card/cblas/arm64/ -I/home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/design/conv/include -I/home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/design/conv/src -I/home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/design/pool/include -I/home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/design/pool/src -I/home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/design/deconv/include -I/home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/design/deconv/src -I"../src" -I/home/ml1/guruprasad/XilinxPackages/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv -c -fmessage-length=0 -MT"src/software/swkernels/xi_eltwiseadd_top.o" -MMD -MP -MF"src/software/swkernels/xi_eltwiseadd_top.d" -MT"src/software/swkernels/xi_eltwiseadd_top.o" -o "src/software/swkernels/xi_eltwiseadd_top.o" "../src/software/swkernels/xi_eltwiseadd_top.cpp" -sds-hw PoolTop pooling_layer_dp_2xio_top.cpp  -clkid 2 -sds-end -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "/home/ml1/guruprasad/XilinxPackages/zcu104-rv-ss-2018-2/zcu104_rv_ss"
Create data motion intermediate representation
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:30:13: warning: unknown pragma ignored [-Wunknown-pragmas]
#pragma GCC push_options
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:31:13: warning: unknown pragma ignored [-Wunknown-pragmas]
#pragma GCC target ("+nothing+simd")
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:38:9: error: unknown type name '__Int8x8_t'
typedef __Int8x8_t int8x8_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:39:9: error: unknown type name '__Int16x4_t'
typedef __Int16x4_t int16x4_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:40:9: error: unknown type name '__Int32x2_t'; did you mean '__int32_t'?
typedef __Int32x2_t int32x2_t;
        __int32_t
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:40:20: note: '__int32_t' declared here
typedef signed int __int32_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:41:9: error: unknown type name '__Int64x1_t'; did you mean '__int64_t'?
typedef __Int64x1_t int64x1_t;
        __int64_t
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:43:25: note: '__int64_t' declared here
typedef signed long int __int64_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:42:9: error: unknown type name '__Float16x4_t'
typedef __Float16x4_t float16x4_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:43:9: error: unknown type name '__Float32x2_t'
typedef __Float32x2_t float32x2_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:44:9: error: unknown type name '__Poly8x8_t'
typedef __Poly8x8_t poly8x8_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:45:9: error: unknown type name '__Poly16x4_t'
typedef __Poly16x4_t poly16x4_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:46:9: error: unknown type name '__Uint8x8_t'
typedef __Uint8x8_t uint8x8_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:47:9: error: unknown type name '__Uint16x4_t'
typedef __Uint16x4_t uint16x4_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:48:9: error: unknown type name '__Uint32x2_t'
typedef __Uint32x2_t uint32x2_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:49:9: error: unknown type name '__Float64x1_t'
typedef __Float64x1_t float64x1_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:50:9: error: unknown type name '__Uint64x1_t'
typedef __Uint64x1_t uint64x1_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:51:9: error: unknown type name '__Int8x16_t'; did you mean '__int16_t'?
typedef __Int8x16_t int8x16_t;
        __int16_t
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:38:26: note: '__int16_t' declared here
typedef signed short int __int16_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:52:9: error: unknown type name '__Int16x8_t'
typedef __Int16x8_t int16x8_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:53:9: error: unknown type name '__Int32x4_t'; did you mean '__int32_t'?
typedef __Int32x4_t int32x4_t;
        __int32_t
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:54:9: error: unknown type name '__Int64x2_t'; did you mean '__int64_t'?
typedef __Int64x2_t int64x2_t;
        __int64_t
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:55:9: error: unknown type name '__Float16x8_t'
typedef __Float16x8_t float16x8_t;
/opt/pkt/xilinx_tools/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:56:9: error: unknown type name '__Float32x4_t'
typedef __Float32x4_t float32x4_t;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing /home/ml1/guruprasad/projects/sdk3/ChaiDNN3/src/software/swkernels/xi_eltwiseadd_top.cpp
sds++ log file saved as /home/ml1/guruprasad/projects/sdk3/ChaiDNN3/Debug/_sds/reports/sds_xi_eltwiseadd_top.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/software/swkernels/xi_eltwiseadd_top.o] Error 1
src/software/swkernels/subdir.mk:39: recipe for target 'src/software/swkernels/xi_eltwiseadd_top.o' failed
Re: ChaiDNN build error
Hi @dawn.paul
Please navigate to src/software/swkernels/xi_eltwiseadd_top.cpp line no.38
#ifdef __SDSOC
change it to
#ifndef __SDSOC
Best Regards,
Nutan
Hi @dawn.paul
Please let me know if you could solve the issue
Best Regards,
Nutan
