Compiling sds_clock_counter() function without sds compilers
I wanted to use the following perf_counter in a C++ application (without using sds compiler)
https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/xlp1524548526775.html
As I manually indicated the location of sds_lib.h header file, the compiler found it; but it could not recognise the sds_clock_counter() function
undefined reference to `sds_clock_counter`
Can you please help me how I can compile the sds_clock_counter() function without sds compiler?
Cheers
Re: Compiling sds_clock_counter() function without sds compilers
Did you compile your app with -lsds_lib option ?
$ nm /opt/Xilinx/SDx/2018.2/target/aarch64-linux/lib/libsds_lib.a | grep sds_clock_counter
0000000000000348 T sds_clock_counter
                 U sds_clock_counter
