Custom Platform with XADC
I am trying to make Custom platform for Red Pitaya Board with XADC to generate a signal and send it with RF Output.
The OS is Linux and Now I try to do like zc702_led example, but how should i generate the files into "arm-xilinx-linux-gnueabi" the header file and the static library. Are they the same like  zc702_led? Or should i do some thing different?
Thank you
Issam
Refer to http://www.wiki.xilinx.com/Linux+GPIO+Driver for led example on GPIO.
XADC example -> http://www.wiki.xilinx.com/Zynq+XADC+to+PS+App+Note
Praveen
Hi pvenugo,
I believe he's asking about how to make an SDSoC platform using XADC, not how to use XADC in general.
Hi issam_1987,
Please see this other thread: https://forums.xilinx.com/t5/SDSoC-Development-Environment/SDSOC-Platform-with-XADC/td-p/715748. To answer your question, yes you should be able to treat it just like the LED platform. If you run into issues please post them here.
Sam
