csordas1020
Custom SDSoC Platform with qemu
Hi everybody,
I have had a problem when I wanted to generate a custom platform that can be emulated with qemu.
I used write_dsa command to generate Device Support Archive with -include_emulation switch:
write_dsa -force -include_emulation /home/csordas/Xilinx_projects/Vivado_projects/ZC706_platform_with_external_DDR/zc706_platform_ext_ddr.dsa
The result is:
ERROR: [Common 17-69] Command failed: To use the '-include_emulation' switch, you must provide the Project property 'dsa.emu_user_prop_json'.
Could anyone help me what does this property do and what value should I set to in order to get a platform that I can emulate with qemu.
Thanks in advance.
