Visitor eshea
Does Cmake support SDx compilers?
I am using SDx 2018.1 and Ubuntu 16.04 LTS. When I try to build source code with the sdscc/sds++ compilers, Cmake complains and says "The C compiler "/opt/Xilinx/SDx/2018.1/bin/sdscc" is not able to compile a
simple test program." I am running the below command and set the $CC and $CXX variables to /opt/Xilinx/SDx/2018.1/bin/sdscc and /opt/Xilinx/SDx/2018.1/bin/sds++, respectively:
cmake -G "Eclipse CDT4 - Unix Makefiles" -DCMAKE_BUILD_TYPE:string="Release" -DBUILD_SHARED_LIBS:bool=on -DCMAKE_INSTALL_PREFIX:path="%USERPROFILE%" -DCMAKE_LIBRARY_PATH:path="%USERPROFILE%" -DCMAKE_INCLUDE_PATH:path="%USERPROFILE%\include" ../openjpeg-2.3.0
When I execute this command with gcc/g++ compilers, it works - I am able to open it in Eclipse, and build the project to create the executables. When I execute this command with arm-linux-gnueabihf-gcc and arm-linux-gnueabihf-g++, it is able to build (3rd image down). However, using the sdscc and sds++ compilers creates the error below so it's not able to build, and opening it in SDx does not work when I try to compile. My error and output log files are attached.
Re: Does Cmake support SDx compilers?
Hi Eshea,
We are using CMake based cross-compilation in combination with xfOpenCV to create Computer Vision designs, see https://github.com/Xilinx/PYNQ-ComputerVision/tree/master/overlays
More specifically, we have collected all necessary cross-compilation settings in a .cmake toolchain file: https://github.com/Xilinx/PYNQ-ComputerVision/blob/master/frameworks/cmakeModules/toolchain_sdx2017.4.cmake
This cross compilation file as passed into cmake using -DCMAKE_TOOLCHAIN_FILE, for example:
$ cmake .. -DCMAKE_TOOLCHAIN_FILE=<properPath>/toolchain_sdx2017.4.cmake
For more details, please have a look at: https://github.com/Xilinx/PYNQ-ComputerVision/blob/master/overlays/README.md
Kristof
