Newbie changan1995
ERROR: [SdsCompiler 83-5031] Problem detected in Vivado HLS run - unable to find solution implementation directory for sha256_hw
Same problem in SDx on Windows 10.
Software build is alright, it is fine working on Linux (said my colleague)
ERROR: [SdsCompiler 83-5031] Problem detected in Vivado HLS run - unable to find solution implementation directory for sha256_hw C:/Users/chang/workspace/pj3/Debug/_sds/vhls/sha256_hw/solution/impl/ip. For possible causes, review C:/Users/chang/workspace/pj3/Debug/_sds/vhls/sha256_hw/solution/solution.log or C:/Users/chang/workspace/pj3/Debug/_sds/vhls/sha256_hw_vivado_hls.log.
C:/Users/chang/workspace/pj3/Debug/_sds/vhls/sha256_hw_vivado_hls.log (last 20 lines):
0x000000005DE62C37 (0x000000AEF08FEE69 0x000000AEF08FEE69 0x0000020FC7D276D0 0x0000000000000001), TclEvalObjEx() + 0x157 bytes(s)
0x000000005DE62ACD (0x0000020FC7D23130 0x0000000000000000 0x000000AEF08FEEF8 0x000000AEF08FEE01), Tcl_EvalObjEx() + 0x1D bytes(s)
0x00007FF83597299F (0x0000020FC78F5EA0 0x0000020FC78F6020 0x0000020FC78F5EA0 0x0000000000000000), Java_ui_frmwork_commandi_undo() + 0x2259F bytes(s)
0x00007FF835972B3E (0x00007FF835D0F318 0x0000000000000000 0x0000020FC78F5EA0 0x0000000000000000), Java_ui_frmwork_commandi_undo() + 0x2273E bytes(s)
0x00007FF8359686EA (0x0000020FC78DC720 0x0000020F00000000 0x0000020FC78D16C0 0x000000000000000E), Java_ui_frmwork_commandi_undo() + 0x182EA bytes(s)
0x00007FF835968AB7 (0x0000020FC78D2300 0x000000000000021B 0x000000AEF08FF5D8 0x0000000000000060), Java_ui_frmwork_commandi_undo() + 0x186B7 bytes(s)
0x00007FF837FA14E4 (0x0000020FC7D276D0 0x000000AEF08FF5D8 0xFFFFFFFFFFFFFFFF 0x5F736B7361746E6F), ?eval_in_tcl_throw@task_manager@tcltasks@hdi@@SAHPEBD0_N@Z() + 0x254 bytes(s)
0x00007FF837FA42F6 (0x676F6C2E736C685F 0x000000AEF08FF800 0x0000842B182FEE2B 0x6168732F736C6876), ?retrieve_except_msg_instance@task_manager@tcltasks@hdi@@SA_NAEAV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z() + 0x4C6 bytes(s)
0x000000005DE611FC (0x0000020F00000000 0x0000020F0000000E 0x0000020FC5FA74E0 0x0000000000000000), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000005DE61681 (0x0000020FC7D23D30 0x000000000000000E 0x0000000000000001 0x000000AEF08FF9E9), Tcl_EvalObjv() + 0x51 bytes(s)
0x000000005DE62C37 (0x000000000000000C 0x000000AEF08FF9E9 0x000000000000000C 0x0000020FC7D276D0), TclEvalObjEx() + 0x157 bytes(s)
0x000000005DE62ACD (0x0000000000000058 0x0000000000000000 0x0000000000000058 0x0000020FC7D1F800), Tcl_EvalObjEx() + 0x1D bytes(s)
0x00007FF87EF546AA (0x0000000000000000 0x0000020FC7D231F0 0x0000020FC7D276D0 0x0000000000000000)
0x000000005DED6BE1 (0x0000020FC5F55680 0x00007FF8943C2CE0 0x00007FF8949590A8 0x0000000000000000), Tcl_Main() + 0x471 bytes(s)
0x00007FF837FCF369 (0x0000020FC5F55680 0x0000000000000000 0x0000000000000000 0x0000000000000000), ?join@HCTNativeThread@@QEAAXXZ() + 0x39 bytes(s)
0x00007FF8948BC4CE (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), _o_ceil() + 0x4E bytes(s)
0x00007FF897743034 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), BaseThreadInitThunk() + 0x14 bytes(s)
0x00007FF8980B1471 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), RtlUserThreadStart() + 0x21 bytes(s)
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'C:/Users/chang/workspace/pj3/Debug/_sds/vhls/hs_err_pid24268.log' for details
sdscc log file saved as C:/Users/chang/workspace/pj3/Debug/_sds/reports/sds_sha256.log
Re: ERROR: [SdsCompiler 83-5031] Problem detected in Vivado HLS run - unable to find solution implementation directory for sha256_hw
Hi @changan1995
Please provide more details about project.
Is it example project provided by Xilinx?
Send below logs
Best Regards,
Nutan
Best Regards,
Nutan
Observer stefanausbo
Hi @nutang
are there any solutions about this issue?
I have the same problem with a different function. When I want to  push the function to hardware I get the same error. On software build I get no errors.
