Visitor nestorai
Error building xfOpencv using Zybo
I am trying to build xfOpencv following this tutorial, and the section Using the xfOpenCV Library on a Custom Platform, but when I try to compile I get these errors:
09:58:24 **** Incremental Build of configuration Debug for project Test ****
make pre-build main-build
sdsoc_make_clean Debug
Building target: Test.elf
Invoking: SDS++ Linker
sds++ -L/opt/Xilinx/SDK/2017.3/data/embeddedsw/ThirdParty/opencv/aarch32/lib -o "Test.elf"  ./src/xf_accumulate_image_accel.o ./src/xf_accumulate_image_tb.o   -lopencv_core -lopencv_imgproc -lopencv_imgcodecs -lopencv_features2d -lopencv_calib3d -lopencv_flann -llzma -ltiff -lpng16 -lz -ljpeg -ldl -lrt -lwebp -dmclkid 1  -sds-sys-config linux -sds-proc a9_0 -sds-pf "zybo"
Removing implementation files from previous run
Analyzing object files
... /home/user/workspace/Test/Debug/src/xf_accumulate_image_accel.o
... /home/user/workspace/Test/Debug/src/xf_accumulate_image_tb.o
Using prebuilt hardware
Skipping block diagram (BD), address map, port information and device registration for partition 0
Prepare hardware access API functions
Create accelerator stub functions
Compile hardware access API functions
Compile accelerator stub functions
Enable generation of boot files
Link application ELF file
/opt/Xilinx/SDx/2017.2/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: no se puede encontrar -llzma
/opt/Xilinx/SDx/2017.2/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: no se puede encontrar -ltiff
/opt/Xilinx/SDx/2017.2/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: no se puede encontrar -lpng16
/opt/Xilinx/SDx/2017.2/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: no se puede encontrar -lz
/opt/Xilinx/SDx/2017.2/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: no se puede encontrar -ljpeg
/opt/Xilinx/SDx/2017.2/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: no se puede encontrar -lwebp
collect2: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++     /home/user/workspace/Test/Debug/src/xf_accumulate_image_accel.o /home/user/workspace/Test/Debug/src/xf_accumulate_image_tb.o /home/user/workspace/Test/Debug/_sds/swstubs/portinfo.o -L/opt/Xilinx/SDK/2017.3/data/embeddedsw/ThirdParty/opencv/aarch32/lib -lopencv_core -lopencv_imgproc -lopencv_imgcodecs -lopencv_features2d -lopencv_calib3d -lopencv_flann -llzma -ltiff -lpng16 -lz -ljpeg -ldl -lrt -lwebp   -L /opt/Xilinx/SDx/2017.2/target/aarch32-linux/lib -L/home/user/workspace/Test/Debug/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o /home/user/workspace/Test/Debug/_sds/swstubs/Test.elf'
make: *** [Test.elf] Error 1
sds++ log file saved as /home/user/workspace/Test/Debug/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
makefile:45: fallo en las instrucciones para el objetivo 'Test.elf'
09:58:27 Build Finished (took 3s.171ms)
In the tutorial, step 21, I have to include several libraries that does not appear in my "<OpenCV_location>\lib" location, such as tiff, lzma,... I am using "/opt/Xilinx/SDK/2017.3/data/embeddedsw/ThirdParty/opencv/aarch32/lib" as my "<OpenCV_location>\lib", I am not sure if this path is the one needed by Zybo, but it is the only one that I have found. I do not know if I have to include another library path, or if I have to install these missing libraries manually.
I am using SDx 2017.2 in Ubuntu 16.04
Thanks so much.
Tags (2)
Re: Error building xfOpencv using Zybo
I think that lzma, tiff, png16, z, jepg and webp can not be found. Can you share a screenshot with Include Paths and Libraries search path from C/C++ Build Settings?
Best regards,
Bogdan
