Participant yan0110
Failed comparing software and hardware performance
Hi, I tried to compare software and hardware performance with the bilateral_filter template in ZCU104 platform. But there is a warning and can not get the comparation of the software and hardware performance.
WARNING: [PerfEst 83-3800] Software run data for function xf::bilateralFilter<3,1,0,2160,3840,1> not found in file swdata.xml. Continuing without comparison to software run data
For graph with functions: xf::bilateralFilter<3,1,0,2160,3840,1>:xf_bilateral_filter_accel.cpp:34
Estimated hardware latency = 33887482
Estimated resource usage:
dsps used = 17/1728
bram used = 20/312
luts used = 18742/230400
FFs used = 19239/460800image.png
How can I solve this problem?
Many thanks.
Participant yan0110
Re: Failed comparing software and hardware performance
Hi, I found out what my problem was. Because I didn't choose the Standalone as System configuration.
Hi @yan0110
Is your host remote?
Best Regards,
Nutan
Participant yan0110
Hi, @nutang. Thanks for your reply.
I ran the demo in SDSoC and I also configurated the IP.
I did the Performance Estimation according to the SDSoC Environment Tutorial: Introduction(https://github.com/Xilinx/SDSoC-Tutorials/blob/master/getting-started-tutorial/lab-2-performance-estimation.md). I can run the demo using "./ bilateral_filter.elf im0.jpg" command in Tera Term, but I don't knowl how to collect software run data. When I clicked the Click Here, there was also the same warning:
dsps used = 17/1728
bram used = 20/312
Hope to your reply.
Many thanks.
Hi @yan0110
Please let me know your SDSoC version
Also, confirm if you are connecting board remotely or to the local host.
Best Regards,
Nutan
Participant yan0110
Both of the version of my SDSoC and reVISION Stack are 2018.3. And I connected the ZCU104 board to my local PC.
Many thanks.
Participant yan0110
